Help Center/ Distributed Message Service for RabbitMQ/ User Guide/ Managing Instances/ Viewing and Modifying Basic Information of a RabbitMQ Instance
Updated on 2024-10-25 GMT+08:00
This section describes how to view the details, and modify the basic information of a RabbitMQ instance on the console.
After creating a RabbitMQ instance, you can modify some configurations of it as required, including the instance name, description, and security group.
Prerequisite
You can modify basic information of a RabbitMQ instance when the instance is in the Running state.
Viewing RabbitMQ Instance Details
  1. Log in to the console.
  2. In the upper left corner, click and select a region.
    Select the region where your RabbitMQ instance is.
  3. Click and choose Middleware > Distributed Message Service for RabbitMQ to open the console of DMS for RabbitMQ.
  4. RabbitMQ instances can be queried by filters. Current filters include the tag, status, name, connection address, and ID. Only enterprise users can use enterprise projects for filtering. For RabbitMQ instance statuses, see Table 1.
    Table 1 RabbitMQ instance status description
    Status
    Creating
    The instance is being created.
    Creation failed
    The instance failed to be created.
    Running
    The instance is running properly.
    Only instances in the Running state can provide services.
    Faulty
    The instance is not running properly.
    Starting
    The status between Frozen and Running.
    Changing
    The instance specifications are being changed.
    Change failed
    The instance specifications failed to be changed.
    Frozen
    The instance is frozen.
    Freezing
    The status between Running and Frozen.
    Upgrading
    The instance is being upgraded.
    Rolling back
    The instance is being rolled back.
    Binning
    The instance is being moved to Recycle Bin.
    Binned
    The instance is in Recycle Bin.
    Recovering
    The instance is being recovered from Recycle Bin.
  5. Click the name of the RabbitMQ instance and view the instance details.
    Table 2 and Table 3 describe the parameters for connecting to an instance. For details about other parameters, see the Basic Information tab page of the instance on the console.
    Table 2 Connection parameters (RabbitMQ 3.x.x)
    Instance Address (Private Network)
    Address for connecting to the instance when public access is disabled.
    Mgmt. UI Address
    Address for connecting to the instance management UI when public access is disabled.
    Public Access
    Whether public access has been enabled.
    Instance Address (Public Network)
    Address for connecting to the instance when public access is enabled.
    Mgmt. UI Address (Public Network)
    Address for connecting to the instance management UI when public access is enabled.
    Table 3 Connection parameters (RabbitMQ AMQP-0-9-1)
    ACL
    Whether to enable ACL.
    When ACL is enabled, message production and consumption require authentication.
    Select the region where your RabbitMQ instance is in.
  4. Click a RabbitMQ instance name to go to the instance details page.
  5. Modify the following parameters if needed:
    Table 4 Modifiable RabbitMQ parameters
    How to Modify
    Result
    Instance Name
    Click , enter a new name, and click .
    Naming rules: 4–64 characters; starts with a letter; can contain only letters, digits, hyphens (-), and underscores (_).
    The modification result is displayed in the upper right corner of the page.
    Enterprise Project
    Click , select a new enterprise project from the drop-down list, and click .
    Only for enterprise users. Modifying this parameter does not restart the instance.
    Click , enter a new description, and click .
    0 to 1024 characters.
    Security Group
    Click , select a new security group from the drop-down list, and click .
    Public Access
    See Configuring RabbitMQ Public Access.
    You will be redirected to the Background Tasks page, which displays the modification progress and result.
    ACL
    Click or to configure ACL.
    This parameter is supported only for RabbitMQ AMQP-0-9-1 instances.
    The modification result is displayed at the top of the page.
