Viewing RabbitMQ Audit Logs
With Cloud Trace Service (CTS), you can record operations associated with DMS for RabbitMQ for later query, audit, and backtrack operations.
Prerequisite
CTS has been enabled.
DMS for RabbitMQ Operations Supported by CTS
Operation |
Resource Type |
Trace Name |
Successfully deleting a background task |
rabbitmq |
deleteDMSBackendJobSuccess |
Failing to delete a background task |
rabbitmq |
deleteDMSBackendJobFailure |
Successfully creating an order for creating an instance |
rabbitmq |
createDMSInstanceOrderSuccess |
Failing to create an order for creating an instance |
rabbitmq |
createDMSInstanceOrderFailure |
Successfully creating an order for modifying an instance |
rabbitmq |
modifyDMSInstanceOrderSuccess |
Failing to create an order for modifying an instance |
rabbitmq |
modifyDMSInstanceOrderFailure |
Successfully scaling up an instance |
rabbitmq |
extendDMSInstanceSuccess |
Failing to scale up an instance |
rabbitmq |
extendDMSInstanceFailure |
Successfully resetting instance password |
rabbitmq |
resetDMSInstancePasswordSuccess |
Failing to reset instance password |
rabbitmq |
resetDMSInstancePasswordFailure |
Successfully deleting an instance that failed to be created |
rabbitmq |
deleteDMSCreateFailureInstancesSuccess |
Failing to delete an instance that failed to be created |
rabbitmq |
deleteDMSCreateFailureInstancesFailure |
Successfully deleting multiple instances at a time |
rabbitmq |
batchDeleteDMSInstanceSuccess |
Failing to delete multiple instances at a time |
rabbitmq |
batchDeleteDMSInstanceFailure |
Successfully modifying instance information |
rabbitmq |
modifyDMSInstanceInfoSuccess |
Failing to modify instance information |
rabbitmq |
modifyDMSInstanceInfoFailure |
Successfully deleting multiple instance tasks at a time |
rabbitmq |
batchDeleteDMSInstanceTask |
Successfully unfreezing an instance |
rabbitmq |
unfreezeDMSInstanceTaskSuccess |
Failing to unfreeze an instance |
rabbitmq |
unfreezeDMSInstanceTaskFailure |
Successfully freezing an instance |
rabbitmq |
Failing to freeze an instance |
rabbitmq |
Successfully deleting an instance task |
rabbitmq |
deleteDMSInstanceTaskSuccess |
Failing to delete an instance task |
rabbitmq |
deleteDMSInstanceTaskFailure |
Successfully creating an instance task |
rabbitmq |
createDMSInstanceTaskSuccess |
Failing to create an instance task |
rabbitmq |
createDMSInstanceTaskFailure |
Successfully submitting a request for scaling up an instance |
rabbitmq |
extendDMSInstanceTaskSuccess |
Failing to submit a request for scaling up an instance |
rabbitmq |
extendDMSInstanceTaskFailure |
Successfully submitting a request for modifying instance information |
rabbitmq |
modifyDMSInstanceInfoTaskSuccess |
Failing to submit a request for modifying instance information |
rabbitmq |
modifyDMSInstanceInfoTaskFailure |
Successfully restoring the instance from Recycle Bin |
rabbitmq |
out_recycleTaskSuccess |
Failing to restore the instance from Recycle Bin |
rabbitmq |
out_recycleTaskFailure |
Viewing Audit Logs
