Monitoring Metrics for RabbitMQ 3.x.x
Introduction
This section describes metrics reported by DMS for RabbitMQ to Cloud Eye as well as their namespaces and dimensions. You can use the Cloud Eye console or APIs to query the metrics and alarms of RabbitMQ instances. You can also view the metrics on the Monitoring Details page on the DMS (for RabbitMQ) console.
Cloud Eye supports a maximum of four hierarchical dimensions that are numbered from 0 to 3. For example, if the dimension information of a monitoring metric is "rabbitmq_instance_id,rabbitmq_node", the dimension of "rabbitmq_instance_id" is numbered 0 and that of "rabbitmq_node" is numbered 1.
Namespace
SYS.DMS
Instance Metrics
Metric ID |
Metric Name |
Description |
Value Range |
Unit |
Conversion Rule |
Dimension |
Monitoring Period (Raw Data) |
connections |
Connections |
Number of connections in the RabbitMQ instance |
≥ 0 |
Count |
N/A |
rabbitmq_instance_id |
1 minute |
channels |
Channels |
Number of channels in the RabbitMQ instance |
0–2047 |
Count |
N/A |
1 minute |
queues |
Queues |
Number of queues in the RabbitMQ instance |
0–7,000 |
Count |
N/A |
1 minute |
consumers |
Consumers |
Number of consumers in the RabbitMQ instance |
0–280,000 |
Count |
N/A |
1 minute |
messages_ready |
RabbitMQ instance Available Messages |
Number of messages that can be consumed in the RabbitMQ instance |
0–10,000,000 |
Count |
N/A |
1 minute |
messages_unacknowledged |
Unacknowledged Messages |
Total number of messages that have been consumed but not acknowledged in a RabbitMQ instance |
0–10,000,000 |
Count |
N/A |
1 minute |
publish |
Production Rate |
Rate at which messages are produced in the RabbitMQ instance |
0–25,000 |
Count/s |
N/A |
1 minute |
deliver |
Retrieval Rate (Manual Ack) |
Rate at which messages are consumed (in the manual acknowledgment scenario) in a RabbitMQ instance |
0–25,000 |
Count/s |
N/A |
1 minute |
deliver_no_ack |
Retrieval Rate (Auto Ack) |
Rate at which messages are consumed (in the automatic acknowledgment scenario) in a RabbitMQ instance |
0–50,000 |
Count/s |
N/A |
1 minute |
connections_states_running |
Normal Connections |
Number of starting, tuning, opening, and running connections in the instance This metric is supported for instances purchased on or after May 16, 2022. |
≥ 0 |
Count |
N/A |
1 minute |
connections_states_flow |
Flow Connections |
Number of flow connections in the instance This metric is supported for instances purchased on or after May 16, 2022. |
≥ 0 |
Count |
N/A |
1 minute |
connections_states_block |
Blocked/Blocking Connections |
Number of blocking and blocked connections in the instance This metric is supported for instances purchased on or after May 16, 2022. |
≥ 0 |
Count |
N/A |
1 minute |
connections_states_close |
Closed/Closing Connections |
Number of closing and closed connections in the instance This metric is supported for instances purchased on or after May 16, 2022. |
≥ 0 |
Count |
N/A |
1 minute |
channels_states_running |
Normal Channels |
Number of starting, tuning, opening, and running channels in the instance This metric is supported for instances purchased on or after May 16, 2022. |
≥ 0 |
Count |
N/A |
1 minute |
channels_states_flow |
Flow Channels |
Number of flow channels in the instance This metric is supported for instances purchased on or after May 16, 2022. |
≥ 0 |
Count |
N/A |
1 minute |
channels_states_block |
Blocked/Blocking Channels |
Number of blocking and blocked channels in the instance This metric is supported for instances purchased on or after May 16, 2022. |
≥ 0 |
Count |
N/A |
1 minute |
channels_states_close |
Closed/Closing Channels |
Number of closing and closed channels in the instance This metric is supported for instances purchased on or after May 16, 2022. |
≥ 0 |
Count |
N/A |
1 minute |
queues_states_running |
Normal Queues |
Number of running queues in the instance This metric is supported for instances purchased on or after May 16, 2022. |
≥ 0 |
Count |
N/A |
1 minute |
queues_states_flow |
Flow Queues |
Number of flow queues in the instance This metric is supported for instances purchased on or after May 16, 2022. |
≥ 0 |
Count |
N/A |
1 minute |
connections_states_full |
CONNECTIONS States Full |
Number of connections that reach the upper limit of channels in the instance |
0–1,000,000 |
Count |
N/A |
1 minute |
Broker Metrics
Metric ID |
Metric Name |
Description |
Value Range |
Unit |
Conversion Rule |
Dimension |
fd_used |
File Handles |
Number of file handles used by RabbitMQ in the node |
0–65,535 |
Count |
N/A |
rabbitmq_instance_id,rabbitmq_node |
1 minute |
socket_used |
Socket Connections |
Number of socket connections used by RabbitMQ in the node |
0–50,000 |
Count |
N/A |
1 minute |
proc_used |
Erlang Processes |
Number of Erlang processes used by RabbitMQ in the node |
0–1,048,576 |
Count |
N/A |
1 minute |
mem_used |
Memory Usage |
Memory usage of RabbitMQ in the node |
0–32,000,000,000 |
Byte |
1024(IEC) |
1 minute |
disk_free |
Available Memory |
Available memory of RabbitMQ in the node |
0–500,000,000,000 |
Byte |
1024(IEC) |
1 minute |
rabbitmq_alive |
Node Alive |
Whether the RabbitMQ node is alive This metric is supported for instances purchased in April 2020 or later. |
1: alive 0: not alive |
N/A |
N/A |
1 minute |
rabbitmq_disk_usage |
Disk Capacity Usage |
Disk usage of the RabbitMQ VM This metric is supported for instances purchased in April 2020 or later. |
0~100 |
N/A |
1 minute |
rabbitmq_cpu_usage |
CPU Usage |
CPU usage of the RabbitMQ VM This metric is supported for instances purchased in April 2020 or later. |
0~100 |
N/A |
1 minute |
rabbitmq_cpu_core_load |
Average Load per CPU Core |
Average load of each CPU core of the RabbitMQ VM This metric is supported for instances purchased in April 2020 or later. |
> 0 |
N/A |
N/A |
1 minute |
rabbitmq_memory_usage |
Memory usage of the RabbitMQ VM |
0~100 |
N/A |
1 minute |
rabbitmq_disk_read_await |
Average Disk Read Time |
Average time for each disk I/O read in the monitoring period This metric is supported for instances purchased in June 2020 or later. |
> 0 |
ms |
N/A |
1 minute |
rabbitmq_disk_write_await |
Average Disk Write Time |
Average time for each disk I/O write in the monitoring period This metric is supported for instances purchased in June 2020 or later. |
> 0 |
ms |
N/A |
1 minute |
rabbitmq_node_bytes_in_rate |
Inbound Traffic |
Inbound traffic per second This metric is supported for instances purchased in June 2020 or later. |
> 0 |
Byte/s |
1024(IEC) |
1 minute |
rabbitmq_node_bytes_out_rate |
Outbound Traffic |
Outbound traffic per second This metric is supported for instances purchased in June 2020 or later. |
> 0 |
Byte/s |
1024(IEC) |
1 minute |
rabbitmq_node_queues |
Queues |
Number of queues in the node This metric is supported for instances purchased in June 2020 or later. |
> 0 |
Count |
N/A |
1 minute |
rabbitmq_memory_high_watermark |
Memory High Watermark |
Whether the node has reached the memory high watermark, blocking all producers in the cluster This metric is supported for instances purchased in June 2020 or later. |
1: yes 0: no |
N/A |
N/A |
1 minute |
rabbitmq_disk_insufficient |
Disk High Watermark |
Whether the node has reached the disk high watermark, blocking all producers in the cluster This metric is supported for instances purchased in June 2020 or later. |
1: yes 0: no |
N/A |
N/A |
1 minute |
rabbitmq_disk_read_rate |
Disk Read Speed |
Number of bytes read from the disk of the node each second This metric is supported for instances purchased on or after May 16, 2022. |
≥ 0 |
Byte/s |
1024(IEC) |
1 minute |
rabbitmq_disk_write_rate |
Disk Write Speed |
Number of bytes written to the disk of the node each second This metric is supported for instances purchased on or after May 16, 2022. |
≥ 0 |
Byte/s |
1024(IEC) |
1 minute |
connections_usage |
Connection Usage |
Percentage of current connections to the maximum number of connections This metric is supported for instances purchased since February 18, 2024. |
≥ 0 |
N/A |
1 minute |
Queue Metrics
Metric ID |
Metric Name |
Description |
Value Range |
Unit |
Conversion Rule |
Dimension |
queue_messages_unacknowledged |
Number of messages that have been consumed but not acknowledged in the RabbitMQ queue |
0–10,000,000 |
Count |
N/A |
rabbitmq_instance_id,rabbitmq_queue |
1 minute |
queue_messages_ready |
Queue Available Messages |
Number of messages that can be retrieved in a RabbitMQ queue |
0–10,000,000 |
Count |
N/A |
1 minute |
queue_consumers |
Consumers |
Number of consumers that are subscribed to the queue This metric is supported for instances purchased on or after May 16, 2022. |
≥ 0 |
Count |
N/A |
1 minute |
queue_messages_publish_rate |
Production Rate |
Number of messages sent to the queue each second This metric is supported for instances purchased on or after May 16, 2022. |
≥ 0 |
Count/s |
N/A |
1 minute |
queue_messages_ack_rate |
Consumption Rate (Manual) |
Number of acknowledged messages sent from the queue to clients each second This metric is supported for instances purchased on or after May 16, 2022. |
≥ 0 |
Count/s |
N/A |
1 minute |
queue_messages_deliver_get_rate |
Consumption Rate |
Number of messages sent from the queue each second This metric is supported for instances purchased on or after May 16, 2022. |
≥ 0 |
Count/s |
N/A |
1 minute |
queue_messages_redeliver_rate |
Redelivery Rate |
Number of messages in the queue redelivered each second This metric is supported for instances purchased on or after May 16, 2022. |
≥ 0 |
Count/s |
N/A |
1 minute |
queue_messages_persistent |
Total Persisted Messages |
Total number of persisted messages in the queue. This is always 0 for transient queues. This metric is supported for instances purchased on or after May 16, 2022. |
≥ 0 |
Count |
N/A |
1 minute |
queue_messages_ram |
Total Messages in RAM |
Total number of messages in the queue that are kept in RAM This metric is supported for instances purchased on or after May 16, 2022. |
≥ 0 |
Count |
N/A |
1 minute |
queue_memory |
Bytes Consumed by Erlang |
Bytes of memory consumed by the Erlang process associated with the queue, including stack, heap, and internal structures This metric is supported for instances purchased on or after May 16, 2022. |
≥ 0 |
Byte |
1024(IEC) |
1 minute |
queue_message_bytes |
Total Message Size |
Total number of bytes of all messages in the queue This metric is supported for instances purchased on or after May 16, 2022. |
≥ 0 |
Byte |
1024(IEC) |
1 minute |
If a monitored object has multiple dimensions, the dimensional level of specific metrics is required when you use APIs to query the metrics.
For example, to query the disk capacity usage (rabbitmq_disk_usage) of a RabbitMQ node, its dimension is "rabbitmq_instance_id,rabbitmq_node", indicating that rabbitmq_instance_id is numbered 0 and rabbitmq_node is numbered 1.
- To query a single metric by calling the API, the rabbitmq_node dimension is used as follows:
dim.0=rabbitmq_instance_id,0186688d-fxxx-497bfdda6c8e&dim.1=rabbitmq_node,dms-vm-0186688d-rabbitmq-0
0186688d-fxxx-497bfdda6c8e and dms-vm-0186688d-rabbitmq-0 are the dimension values of rabbitmq_instance_id and rabbitmq_node. For details about how to obtain them, see the guide in the Dimension table.
- To batch query metrics by calling the API, the rabbitmq_node dimension is used as follows:
"dimensions": [ { "name": "rabbitmq_instance_id", "value": "0186688d-fxxx-497bfdda6c8e" }, { "name": "rabbitmq_node", "value": "dms-vm-0186688d-rabbitmq-0" } ]0186688d-fxxx-497bfdda6c8e and dms-vm-0186688d-rabbitmq-0 are the dimension values of rabbitmq_instance_id and rabbitmq_node. For details about how to obtain them, see the guide in the Dimension table.
Dimensions
Key |
Value |
RabbitMQ instance ID, for example, 0186688d-fxxx-497bfdda6c8e. To obtain the value, call the Listing All Instances API and extract the value from the response parameters. |
rabbitmq_node |
RabbitMQ instance node, for example, dms-vm-0186688d-rabbitmq-0. To obtain the value, call the Querying Instance Monitoring Dimensions API and extract the value from the response parameters. |
rabbitmq_queue |
RabbitMQ instance queue name, for example, Queue-01. To obtain the value, call the Querying Instance Monitoring Dimensions API and extract the value from the response parameters. |
