Monitoring Metrics for RabbitMQ AMQP-0-9-1
Introduction
This section describes metrics reported by DMS for RabbitMQ to Cloud Eye as well as their namespaces and dimensions. You can use the Cloud Eye console or APIs to query the metrics and alarms of RabbitMQ instances. You can also view the metrics on the Monitoring Details page on the DMS (for RabbitMQ) console.
Cloud Eye supports a maximum of four hierarchical dimensions that are numbered from 0 to 3. For example, if the dimension information of a monitoring metric is "rabbitmq_instance_id,rabbitmq_vhost", the dimension of "rabbitmq_instance_id" is numbered 0 and that of "rabbitmq_vhost" is numbered 1.
Namespace
SYS.DMS
Instance Metrics
Metric ID |
Metric Name |
Description |
Value Range |
Unit |
Conversion Rule |
Dimension |
Monitoring Period (Raw Data) |
connections |
Connections |
Number of connections in the RabbitMQ instance |
≥ 0 |
Count |
N/A |
rabbitmq_instance_id |
1 minute |
channels |
Channels |
Number of channels in the RabbitMQ instance |
0–2,000 |
Count |
N/A |
1 minute |
queues |
Queues |
Number of queues in the RabbitMQ instance |
0–1,000 |
Count |
N/A |
1 minute |
consumers |
Consumers |
Number of consumers in the RabbitMQ instance |
≥ 0 |
Count |
N/A |
1 minute |
messages_ready |
RabbitMQ instance Available Messages |
Number of messages that can be consumed in the RabbitMQ instance |
0–10,000,000 |
Count |
N/A |
1 minute |
publish |
Production Rate |
Rate at which messages are produced in the RabbitMQ instance |
≥ 0 |
Count/s |
N/A |
1 minute |
instance_bytes_in_rate |
Message Production |
Number of bytes produced in the RabbitMQ instance per second |
≥ 0 |
Byte/s |
1024(IEC) |
1 minute |
instance_bytes_out_rate |
Message Consumption |
Number of bytes consumed from the RabbitMQ instance per second |
≥ 0 |
Byte/s |
1024(IEC) |
1 minute |
deliver_get |
Consumption Rate |
Number of messages consumed in real time by the RabbitMQ instance per second |
≥ 0 |
Count/s |
N/A |
1 minute |
instance_disk_usage |
Instance Disk Usage |
Instance disk usage |
0–100 |
N/A |
1 minute |
instance_tps |
Instance Transactions Per Second |
Number of requests processed by a RabbitMQ instance per second |
0–10,000,000 |
Count |
N/A |
1 minute |
instance_connections_usage |
Instance connections usage |
Percentage of the total number of connections to the maximum number of connections allowed by the instance Some instances do not support this metric. Contact customer service. |
0–100 |
N/A |
1 minute |
Virtual Host Metrics
Metric ID |
Metric Name |
Description |
Value Range |
Unit |
Conversion Rule |
Dimension |
vhost_connections |
Connections |
Total number of connections in the virtual host |
≥ 0 |
Count |
N/A |
rabbitmq_instance_id,rabbitmq_vhost |
1 minute |
vhost_channels |
Channels |
Total number of channels in the virtual host |
≥ 0 |
Count |
N/A |
1 minute |
vhost_queues |
Queues |
Total number of queues in the virtual host |
≥ 0 |
Count |
N/A |
1 minute |
vhost_consumers |
Consumers |
Total number of consumers in the virtual host |
≥ 0 |
Count |
N/A |
1 minute |
vhost_messages_ready |
Total number of messages that can be consumed from the virtual host |
≥ 0 |
Count |
N/A |
1 minute |
vhost_messages_publish_rate |
Production Rate |
Number of messages produced in real time in the virtual host per second |
≥ 0 |
Count/s |
N/A |
1 minute |
vhost_messages_deliver_get_rate |
Consumption Rate |
Number of messages consumed in real time in the virtual host per second |
≥ 0 |
Count/s |
N/A |
1 minute |
vhost_bytes_in_rate |
Message Creation |
Number of bytes produced in the virtual host per second |
≥ 0 |
Byte/s |
1024(IEC) |
1 minute |
vhost_bytes_out_rate |
Message Retrieval |
Number of bytes consumed from the virtual host per second |
≥ 0 |
Byte/s |
1024(IEC) |
1 minute |
vhost_tps |
Vhost Transaction Per Second |
Number of requests processed by the current virtual host per second |
≥ 0 |
Count |
N/A |
1 minute |
Exchange Metrics
Metric ID |
Metric Name |
Description |
Value Range |
Unit |
Conversion Rule |
Dimension |
exchange_messages_publish_rate |
Production Rate |
Number of messages produced in real time in the exchange per second |
≥ 0 |
Count/s |
N/A |
rabbitmq_instance_id,rabbitmq_vhost,rabbitmq_vhost_exchange |
1 minute |
exchange_bytes_in_rate |
Message Creation |
Number of bytes produced in the exchange per second |
≥ 0 |
Byte/s |
1024(IEC) |
1 minute |
Queue Metrics
Metric ID |
Metric Name |
Description |
Value Range |
Unit |
Conversion Rule |
Dimension |
queue_messages_ready |
Queue Available Messages |
Number of messages that can be retrieved in a RabbitMQ queue |
≥ 0 |
Count |
N/A |
rabbitmq_instance_id,rabbitmq_vhost,rabbitmq_vhost_queue |
1 minute |
queue_consumers |
Consumers |
Number of consumers that are subscribed to the queue |
≥ 0 |
Count |
N/A |
1 minute |
queue_messages_publish_rate |
Production Rate |
Number of messages sent to the queue each second |
≥ 0 |
Count/s |
N/A |
1 minute |
queue_messages_deliver_get_rate |
Consumption Rate |
Number of messages sent from the queue each second |
≥ 0 |
Count/s |
N/A |
1 minute |
queue_bytes_in_rate |
Number of messages produced in real time in the queue per second |
≥ 0 |
Byte/s |
1024(IEC) |
1 minute |
queue_bytes_out_rate |
Number of messages consumed in real time in the queue per second |
≥ 0 |
Byte/s |
1024(IEC) |
1 minute |
If a monitored object has multiple dimensions, the dimensional level of specific metrics is required when you use APIs to query the metrics.
For example, to query the total number of connections (vhost_connections) of a RabbitMQ virtual host, its dimension is "rabbitmq_instance_id,rabbitmq_vhost", indicating that rabbitmq_instance_id is numbered 0 and rabbitmq_vhost is numbered 1.
- To query a single metric by calling the API, the rabbitmq_vhost dimension is used as follows:
dim.0=rabbitmq_instance_id,0186688d-fxxx-497bfdda6c8e&dim.1=rabbitmq_vhost,default
0186688d-fxxx-497bfdda6c8e and default are the dimension values of rabbitmq_instance_id and rabbitmq_vhost. For details about how to obtain them, see the guide in the Dimension table.
- To batch query metrics by calling the API, the rabbitmq_vhost dimension is used as follows:
"dimensions": [ { "name": "rabbitmq_instance_id", "value": "0186688d-fxxx-497bfdda6c8e" }, { "name": "rabbitmq_vhost", "value": "default" } ]0186688d-fxxx-497bfdda6c8e and default are the dimension values of rabbitmq_instance_id and rabbitmq_vhost. For details about how to obtain them, see the guide in the Dimension table.
Dimension
Key |
Value |
RabbitMQ instance ID, for example, 0186688d-fxxx-497bfdda6c8e. To obtain the value, call the Listing All Instances API and extract the value from the response parameters. |
rabbitmq_vhost |
RabbitMQ instance virtual host name, for example, default. To obtain the value, call the Querying Instance Monitoring Dimensions API and extract the value from the response parameters. |
RabbitMQ instance exchange name, for example, Exchange-01. To obtain the value, call the Querying Instance Monitoring Dimensions API and extract the value from the response parameters. |
RabbitMQ instance queue name, for example, Queue-01. To obtain the value, call the Querying Instance Monitoring Dimensions API and extract the value from the response parameters. |
