Configuring RabbitMQ Delayed Messages
Delayed messages enter queues for consumers to consume after a specified delay, instead of being received by consumers immediately after being sent.
Notes and Constraints
The delay exchange function is available only in RabbitMQ AMQP-0-9-1.
Configuring Delayed Messages
You can implement delayed messages in any of the following ways:
- Setting a delay exchange: Messages sent to a delay exchange carry the same delay time by default.
- Setting the message delay time: Each message can be set with different delay time.
- Setting the time to live and dead letter queue: Expired messages are automatically routed to the dead letter queue.
The following example shows how to configure a delay exchange on a Java client:
Map<String, Object> args = new HashMap<String, Object>();
args.put("x-delayed-type", "direct");
channel.exchangeDeclare("exchange", "x-delayed-message", true, false, args);
The following example shows how to set the message delay time on a Java client.
final HashMap<String, Object> headers = new HashMap<>();
headers.put("x-delay", 10000);
final AMQP.BasicProperties.Builder properties = new AMQP.BasicProperties().builder().headers(headers);
// publish a batch of messages to the main exchange
for (int i = 0; i < messageCount; i++) {
channel.basicPublish(exchangeName, routingKey, properties.build(),
("x-delayed-message-" + i).getBytes());
The following example shows how to set the time to live and dead letter queue on a Java client:
channel.queueDeclare("dlq", false, false, false, null);
channel.exchangeDeclare("dlx", BuiltinExchangeType.DIRECT);
channel.queueBind("dlq", "dlx", "rt");
HashMap<String, Object> arguments = new HashMap<>();
arguments.put("x-dead-letter-exchange", "dlx");
arguments.put("x-dead-letter-routing-key", "rt");
arguments.put("x-message-ttl", 5000);
channel.exchangeDeclare("normal", BuiltinExchangeType.DIRECT);
channel.queueDeclare("normal", true, false, false, arguments);
channel.queueBind("normal", "normal", "key");
channel.basicPublish("normal", "key", null, "ttl".getBytes());
