- What's New
- Function Overview
Service Overview
- What Is CodeArts Req?
- Advantages
- Use Cases
Features
- Multiple Built-in IPD Requirement Models
- E2E Traceability
- Baseline Management and Change Review
- Efficient Cross-Project Requirement Collaboration
- System Feature Management
- Customers' Raw Requirements Management
- Bug Full Lifecycle Management
- Efficient Cross-Organization Collaboration for Bug Tracking and Management
- Bug Trend Analysis and Quality Measurement
- Traceable Fixing Process
- Customizable Fixing Process
- Security
- Permission Management
- Constraints
- Getting Started
User Guide
- CodeArts Req Usage Process
- Purchasing and Authorizing CodeArts Req
- Accessing the CodeArts Req Homepage
- Creating a CodeArts Project
- Managing Scrum Project Requirements
Managing IPD-System Device Project Requirements
- Requirement Management Process
Configuring Common Settings
- Configuring Common Work Item Fields
- Configuring Common Work Item Statuses
- Configuring Work Item Templates
- Configuring Work Item Status Flows
- Configuring Work Item Tags
- Creating Work Item Modules
- Creating Work Types
- Configuring Work Item Status Roll-up Rules
- Configuring Notification Rules
- Viewing Work Item Import/Export Records
- Creating and Managing RRs
- Creating and Managing a Feature Tree and System Features
- Configuring Project Plans
- Creating and Managing R&D Requirements
- Creating and Managing Tasks
- Creating and Managing Bugs
- Reviewing Work Items
- Tracking the Project Progress
Managing IPD-Standalone Software Project Requirements
Common Configuration Management
- Configuring Automatic Roll-up Rules
- Configuring Notifications
- Configuring a Plan
- (Optional) Checking Audit Logs
Best Practices
- CodeArts Req Best Practices
- Best Practices of Scrum Projects
- Using IPD-System Device Projects to Manage RRs of a Smart Watch R&D Project
- Using IPD-System Device Projects to Manage Defects of a Smart Watch R&D Project
- Using IPD-System Device Projects to Perform a Baseline Review (BR) on a Smart Watch R&D Project
- Using IPD-System Device Projects to Manage Feature Trees of a Smart Watch R&D Project
- Huawei E2E DevOps Practice: Managing Requirements
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
Work Items of the Scrum Project
- Creating a Customized Field for a Work Item Type
- Uploading an image
- Obtaining Work Item Completion Rate
- Obtaining Comments on a Specified Work Item
- Querying Labor Hours by User (Single Project)
- Querying Labor Hours by User (Multi-Project)
- Obtaining the Work Item History
- Create work items.
- Querying Work Items of a Project
- Advanced Query Work Item
- Deleting Work Items in Batches
- Querying Work Item Details
- Updating a Work Item
- Deleting a Work Item
- Obtains sub-work items.
- Querying Historical Records of All Work Items in a Project
- Querying the Work Item Transfer Configuration of a Scrum Project
- Creating a Work Item as a Fine-grained Permission User
- Queries the work items associated with the current work item.
- Queries the associated Wikis associated with the current work item.
- Queries the code submission records or branch creation records associated with the current work item.
- Querying Associated Wikis
- Querying Customized Fields of Scrum Work Items
- Downloading an Image
- Uploading an Attachment to a Work Item
- Iteration of the Scrum Project
- User Information
- Project members
- Project Information
- Project Indicators
- Project Statistics
- Modules of the Scrum Project
- Domain of the Scrum Project
- Scrum Project Statuses
- Application Examples
- Appendixes
- Change History
Work Items
- How Can I Assign One Scrum Project Work Item to Multiple Members?
- Why Is a Message Reporting Duplicate File Name Displayed During File Association in a Scrum Project?
- How Do I Handle the Verification Exceptions in the Number of Work Items Imported to an IPD Project?
- How Do I Modify the Recipient After an IPD Project Requirement Is Assigned?
- Member Management
Troubleshooting
- Why Is the Message "You have been invited to run projects with another account. Accept invitation" Displayed When Inviting Other Users to Join My Project in CodeArts Req?
- Why Can't I Create a Project Using "DevOps Full-Process"?
- Why Is a Message Indicating the Field Name Already Exists Displayed When Setting a Work Item Field in a Scrum Project?
Work Items
- Videos
Using a Sample Project
Sample projects use default templates that include work items and processes preset in CodeArts Req. After you select a sample project, the corresponding sample template project is automatically generated for your reference. The work items and code preset in the sample project can be directly used.
Before creating a CodeArts project, you must have permission to create a project. If the Create Project button is not displayed on the homepage, you do not have permission to create projects. In this case, contact the administrator to obtain the permission. For details about how to grant the project creator permission to users, see Configuring a CodeArts Project Creator.
Creating a CodeArts Project Using a Sample Project
- Click Create Project on the service homepage.
- On the Select Template page, select a sample project to create a project. Table 1 lists the supported sample projects.
Table 1 Sample projects Project Type
Project Name
Application Scenario
Scrum
DevOps Full-Process
Agile development and DevOps continuous delivery through an automated E2E process. The templates have preset mind maps and instantiated Scrum work items (promotion, member, and order management), code repositories, code check tasks, build tasks, and pipeline tasks.
Scrum
One-Stop HarmonyOS Application Development
The sample project provides a one-stop distributed application development platform for all scenarios. It supports distributed multi-device development, debugging, and simulation, providing all-round quality and security assurance.
IPD
IPD-System Device
Complex products with embedded software that evolves with hardware. Examples: communications devices, automobiles, home appliances, and consumer electronics.
IT application and platform software with standardized hardware or independent of dedicated hardware. Examples: ERP software, CRM, databases, and network management software.
IPD-Self-Operated Software/Cloud Service
Cloud service development, microservice architecture, and self-operated software scenarios, such as public cloud and Internet application software.
- Select a sample project. On the Create Project page, set related parameters.
Table 2 Creating a project Parameter
Name
Set this parameter as required.
The name of projects under the same tenant must be unique.
Enter only letters, digits, and underscores (_) with a maximum of 128 characters.
Code
This parameter is set for third-party services. A project code is set to facilitate service management.
The value can contain a maximum of 200 characters, including letters, digits, underscores (_), and hyphens (-).
Enter a brief description of the project.
Enter only letters, digits, and underscores (_) with a maximum of 1,024 characters.
- Click OK. The project is created successfully and the project page is displayed.
Related Operations
For a new project, members with the edit permission can choose Settings > General and perform the following operations.
Operation |
Procedure |
Remarks |
Edit basic project information |
Transfer the project creator |
If the project creator is deleted from IAM, the project ownership is automatically transferred to the project manager. If the project creator is also the project manager, the project ownership is transferred to the administrator account. |
Archive a project |
Delete a project |
Manage the project service menu |
Manage project members/permissions |
