On this page
Show all
IPD-System Device Project Reviews
Updated on 2025-01-17 GMT+08:00
IPD-system device projects have three review types: change review (CR), baseline review (BR), and general review (GR). They are described in Table 1.
Table 1 Review types
Review Type
Review Object
Change review (CR)
  • Changing the controlled fields of a raw requirement or bug will initiate a change review. The change will be synchronized to the requirement and bug only after the review is approved.
    The control status of a raw requirement and bug is determined by whether any controlled fields are configured for specific status. A field is deemed under control when a raw requirement or bug is in the specified status.
  • Changing the baselined fields of a system feature or R&D requirement will initiate a change review. The change will be synchronized to the feature and requirement only after the review is approved.
Raw requirements, system features, R&D requirements, and bugs
Baseline review (BR)
To baseline a system feature or R&D requirement, you need to initiate a baseline review. The feature and requirement will be baselined only after the review is approved.
Systems features and R&D requirements
General review (GR)
To review a work item, you can initiate a general review. The work item takes effect only after the review is approved.
