Help Center/
CodeArts Req/
User Guide/
Managing Scrum Project Requirements/
Tracking the Project Progress/
Sending a Project Progress Report
Updated on 2025-11-07 GMT+08:00
You can send project progress reports to the specified recipients.
Creating a Project Progress Report
- Access the CodeArts Req homepage.
- Go to a Scrum project and choose .
- Click
. On the Select Report Template page, select Empty File, System Templates, or Custom Templates. The Empty File is used as an example.
Figure 1 Selecting a report template
- Click OK.
- Set the report title, Recipients, CC Recipients, and report content as required, then click Send.
- Check received reports in the inbox and sent reports in the outbox on the Reports page.
Parent topic: Tracking the Project Progress
