Configuring a Sprint Plan
In a Scrum project, sprints can be used to manage and track versions.
There is a Scrum project, in which you have permission to create sprints. For details about how to set permissions, see Managing Project Permissions.
Creating a Sprint
- Access the CodeArts Req homepage.
- Go to the project homepage and choose .
- Click  above the sprint list. In the Create Sprint dialog box, set related parameters. above the sprint list. In the Create Sprint dialog box, set related parameters.Table 1 Creating a Sprint Parameter Description Sprint Name Sprint name, which can contain a maximum of 60 characters, including letters, digits, periods (.), and underscores (_). Planned Duration Start time and end time of a sprint plan. Description Description of a sprint plan. The value can contain a maximum of 500 characters, including letters, digits, periods (.), and underscores (_).
- Click OK. The sprint is created successfully, and the sprint page is displayed.
    Figure 1 Sprints  By default, the created sprints are displayed on the left in descending order of the creation time. You can click a sprint card on the left to switch to another sprint. The sprint page displays the sprint name, planned sprint time, sprint description, sprint statistics, and work items in the sprint.
Follow-up Operations
After operations in Creating a Sprint are complete, you can perform the following operations.
  | Operation | Description | Constraint and Restriction |
| Edit sprint | Click  | You must have permission to edit sprints. |
| Change sprint status |
 | You must have permission to set statuses for sprints. |
| Delete sprint | Click
 | You must have permission to delete sprints. |
| Plan sprint | You can select unplanned work items or work items under other sprints and drag them to the target sprint (To Do or Doing). | You must have permission to edit sprints. |
| Check and manage sprint |
        Click   in the upper right corner of a sprint to switch the display mode of sprint work items.
 Click  Click Create Work Item to create a Story, Task, or Bug. You can edit the displayed fields on the list page. | All project members can view sprints. To create a work item in a sprint, you must have permission to create and duplicate work items. To modify a work item in the sprint list, you must have permission to edit work items. |
| Edit work item in sprint | For details, see Related Operations, On the Work Item List Page, and On the Work Item Details Page. | You must have the required work item permissions in the project. |
