Updated on 2026-10-26 GMT+08:00
Configuring a Review Checklist Template and Check Items
Review check items can be used for self-check by work item creators and check by review experts or decision makers in a project. Review check items are aggregated using a review checklist template. Review check items used in work items or reviews are also based on the review checklist template. Therefore, you need to create a review checklist template. A review checklist template can contain multiple review check items. After creating a review checklist template, you need to create review check items in the template.
  • A maximum of 100 review checklist templates can be created.
  • A review checklist template can contain a maximum of 50 check items.
  • A review checklist template that has been associated with a work item type or review cannot be deleted.
You must have the permissions of the Tenant Administrator role. For details about how to assign the Tenant Administrator role to a user, see Creating a User Group and Assigning Permissions.
Creating a Review Checklist Template
  1. Access the CodeArts Req homepage and click .
  2. Choose All Account Settings.
  3. Choose Work Item Management > Template Settings > Checklist Templates.
  4. Click Create New Template.
  5. Set the parameters for creating a review checklist template by referring to Table 1.
    Table 1 Parameters for creating a review checklist template
    Template name
    Name of the review checklist template to be created.
    • The name contains a maximum of 50 characters.
    • A tenant can have a maximum of 100 templates.
    • The name must be unique.
    Description of the review checklist template to be created. This parameter is optional.
    It can contain up to 500 characters.
  6. Click OK. The created review checklist template is displayed in the list.
    You can perform the following operations on the created review checklist template.
    Table 2 Managing a review checklist template
    Operation
    Edit review checklist template
    Click . On the displayed page, you can modify the template name and description and create a check item. For details about how to create a check item, see Creating a Review Check Item in the Template.
    Click to copy the review checklist template.
    Delete review checklist template
    Click , read the information, and click Delete.
    • If the current work item type has been associated with a work item type template, cancel the association on the Work Item Type Templates page and then delete template.
    • If the current review checklist template has been used by a review in the project, cancel the association in the review settings of the project and then delete the template.
  3. Choose Work Item Management > Template Settings > Checklist Templates. The existing checklist templates are displayed.
  4. Locate the checklist template for which you want to create a review checklist item and click to go to the template editing page.
  5. Click New check item. The check item creation window is displayed.
  6. Set the parameters for creating a review check item by referring to Table 3.
    Table 3 Parameters for creating a review check item
    Check item name
    Name of the review item to be created.
    The name contains a maximum of 200 characters.
    Description of the review item to be created.
    This parameter is optional. The description is displayed as a prompt in the checklist on the work item creation page.
  7. Click OK. The created review check item is displayed in the list.
    • Click Save to save the check item. It takes effect only after being released.
    • After a released template is modified and saved, you can click Reset template to restore the template to the latest released version.
    • Click Cancel to exit the page for editing the review check item template and cancel the modification.
    You can perform the following operations on the created check item.
    Table 4 Managing a review check item
    Operation
    Edit review check item
    Click to modify the check item name and description.
    Delete review check item
    Click to delete the check item.
