Configuring Common Work Item Statuses
Customize common statuses that can be used by any type of work items in your project.
- An IPD-standalone software project is available, in which you have permission to configure work item templates.
- You have the Tenant Administrator permission.
- A maximum of 150 common fields can be customized in a project.
Configuring Common Statuses in a Project
- Access the CodeArts Req homepage.
- Go to a project and choose .
- In the navigation pane, choose .
- Click Create Status under Add Status. In the displayed dialog box, set the required parameters.
Table 1 Creating a status Parameter
Name
Enter a maximum of 30 characters, including letters, digits, and hyphens (-).
Category
Category of the status.
The options include To Do, Doing, and Done.
Remarks about the status. Enter a maximum of 50 characters, including letters, digits, and hyphens (-).
- Click OK.
The new status is displayed at the end of the list. The parameters in this list are described in the following table.
Table 2 Status list Parameter
Name
System or custom status name. Hover over the header and click
to sort by status name.Created By
The user who creates a status. Hover over the header and click
to sort by creator.Created
Time when a status is created. Hover over the header and click
to sort by creation time.Category
System or custom status category.
to sort by status category.Hover over the header and click
to filter statuses.Status
Work item types that are currently using a system or custom status.
System or custom status description.
Operation
You can edit and delete a status.
To edit a status, click
in this column. - System statuses cannot be edited.
- Custom statuses of the tenant cannot be edited here.
To delete a status, click
in this column.- System statuses cannot be deleted.
- Custom statuses that are currently in use by work items cannot be deleted.
- Deleted statuses cannot be recovered.
- (Optional) Add a common status (for example, CommonStatus01) to the work item status flow.
The following uses the IR work item status flow as an example:
- Under Work Configuration, choose , and click Edit.
- Click
on the left, select CommonStatus01 on the All Statuses panel, and drag it to the status flow canvas. Draw incoming and outgoing transition lines for the status, and click Update Status Flow. Figure 1 Expanding all statuses
- Check this CommonStatus01 status in IRs' status flows on the page.
- Custom common statuses can be configured and used for all types of work items of the current project.
- The IR work item status flow is used as an example. You can add common statuses to other work item templates in the same way, and only need to do this once for each of them.
Related Operations
You can also configure tenant-level statuses in the tenant settings. Then these statuses can be used in the workflow of any work item type. For details, see Configuring Work Item Statuses.
