Updated on 2026-10-26 GMT+08:00
Configuring Common Work Item Statuses
Customize common statuses that can be used by any type of work items in your project.
  • An IPD-system device project is available, and you have permission to configure work item templates for the project.
  • The total number of system and common statuses in a project cannot exceed 50.
Configuring Common Statuses in a Project
  1. Access the CodeArts Req homepage.
  2. Go to a project and choose Settings > Work.
  3. In the navigation pane, choose Work Items > Common Status.
  4. Click Create Status under Add Status. In the displayed dialog box, set the required parameters.
    Table 1 Creating a status
    Name
    Enter a maximum of 30 characters, including letters, digits, and hyphens (-).
    Category
    Category of the status.
    The options include To Do, Doing, and Done.
    Remarks about the status. Enter a maximum of 50 characters, including letters, digits, and hyphens (-).
  5. Click OK.
    The new status is displayed at the end of the list. The parameters in this list are described in the following table.
    Table 2 Status list
    Name
    System or custom status name. Hover over the header and click to sort by status name.
    Created By
    The user who creates a status. Hover over the header and click to sort by creator.
    Created
    Time when a status is created. Hover over the header and click to sort by creation time.
    Category
    System or custom status category.
    Hover over the header and click to sort by status category.
    Hover over the header and click to filter statuses.
    Status
    Work item types that are currently using a system or custom status.
    System or custom status description.
    Operation
    You can edit and delete a status.
    To edit a status, click in this column.
    • System statuses cannot be edited.
    • Custom statuses of the tenant cannot be edited here.
    To delete a status, click in this column.
    • System statuses cannot be deleted.
    • Custom statuses that are currently in use by work items cannot be deleted.
    • Deleted statuses cannot be recovered.
  6. (Optional) Add a common status (for example, CommonStatus01) to the work item status flow.
    The following uses the IR work item status flow as an example:
    1. Under Work Configuration, choose Work Items > Initial Requirement (IR) > Status Flows, and click Edit.
    2. Click on the left, select CommonStatus01 on the All Statuses panel, and drag it to the status flow canvas. Draw incoming and outgoing transition lines for the status, and click Update Status Flow.
      Figure 1 Expanding all statuses
    3. Check this CommonStatus01 status in IRs' status flows on the Work > Req > R&D Requirements page.
      • Custom common statuses can be configured and used for all types of work items of the current project.
      • The IR work item status flow is used as an example. You can add common statuses to other work item templates in the same way, and only need to do this once for each of them.
Related Operations
You can also configure tenant-level statuses in the tenant settings. Then these statuses can be used in the workflow of any work item type. For details, see Configuring Work Item Statuses.
