Help Center/ CodeArts Req/ User Guide/ IPD-System Device Projects/ Work Settings/ Configuring Downstream Projects of R&D Requirements
Updated on 2024-05-21 GMT+08:00
This section describes how to configure the collaboration between R&D requirements and downstream projects.
  1. Open the project, and go to Settings > Work > Downstream Projects.
  2. Click Add Downstream Project. The Add Downstream Project dialog box is displayed.
  3. Search for and select the project to be added.
  4. Click Add to add the project.
    After the project is added successfully, you can select the configured project for collaborative delivery in R&D Requirements. For details, see Delivering.
