Updated on 2026-10-26 GMT+08:00
Creating Work Types
Work types include R&D design, backend development, frontend development, and more. You can customize your own work types and specify whether they are mandatory for work items.
An IPD-standalone software project is available, in which you have permission to configure work types.
Creating a Work Type
  1. Access the CodeArts Req homepage.
  2. Go to a project and choose Settings > Work > Work Types.
  3. Click Create.
    Figure 1 Creating a work type
  4. Enter a work type name.
    The name must be unique in the system.
  5. Click OK.
    You can select this work type when configuring workloads for work items.
    Figure 2 Adding a workload
Configuring Whether Work Types Are Mandatory
  3. Toggle on Mandatory.
    By default, this option is toggled off.
    Figure 3 Configuring work types
    A red asterisk (*) will be displayed next to Work Type on the Add Workload page, indicating that the work type is mandatory.
    Figure 4 Adding a workload
