Updated on 2025-11-07 GMT+08:00
Creating and Completing GRs
When your work items need to be reviewed, perform the following steps to initiate a general review.
A maximum of 20 reviewers can be added.
A maximum of 50 objects can be added to or associated with a single review record.
Creating a GR
  1. Access the CodeArts Req homepage.
  2. On the project homepage, choose Review > General Review. Then click GR.
  3. On the GR page, set the required parameters.
    Table 1 Creating a GR
    GR Title
    Title of the review.
    • Use letters, hyphens (-), underscores (_), commas (,), semicolons (;), colons (:), periods (.), slashes (/), parentheses, and spaces.
    • Include 1 to 256 characters.
    Enter the background, value, and details of the review.
    • Use text, images, or links.
    • Include 1 to 50,000 characters.
    Start time
    The time when you want the review to start.
    Completes
    The time when you want the review to complete.
    Require Decision-Making
    This parameter is available only when Require Decision-Making is enabled on the Settings > Work > Review page.
    If Require Decision-Making is set to No, no approver needs to be specified. The review will skip the decision-making phase.
    Reviewer
    The options of Reviewer can be configured on the Settings > Work > Review page. The default options are project administrator and project manager. You can select only one option.
    Review Expert
    If Review Expert is not set, the review phase will be skipped.
    The options of Review Expert are project members. You can select multiple ones.
    Copy To
    Select the project members you want to inform about this review.
    Associated Object
    Add the objects to be reviewed, including raw requirements, system features, R&D requirements, and bugs.
    Associated Files
    Attachments, wikis, and documents related to the review.
  4. Click Submit.
    You can view the new GR in the general review list.
Related Operations
You can perform the following operations on a draft GR.
Table 2 Basic operations on a draft GR
Operation
Modify title
Click next to a GR title to modify it.
Modify field
Click the target field value in the row of a GR to modify the value. After the modification, click Submit.
Copy link
Click in the Operation column to copy the title, ID, current owner, status, and link information of the requirement to the clipboard.
Delete GR
Click in the Operation column of a GR to delete it.
For a new GR, click in the Operation column to copy the title, ID, current owner, status, and link information of the requirement to the clipboard.
Completing a GR
This operation is performed by the specified review experts and reviewer of a GR.
  2. On the project homepage, choose Review > Change Review.
  3. Click the title of a GR in the To Be Reviewed state. The GR details page is displayed on the right.
  4. On the details page, click Expert Review in the upper right corner. In the displayed dialog box, set the required parameters.
    Figure 1 Review by review experts
    Table 3 Review by review experts
    Result
    Select your review result.
    • Approve: You agree with the change.
    • Reject: You do not agree with the change.
    • Transfer to others: Transfer the review to another review expert.
    Comment
    Your comments on the change. This parameter is required when Result is Approve or Reject.
    • Include 1 to 300 characters.
    Expert Comments
    Comments of other review experts.
  5. Select a review result (Approve or Reject) and click OK.
    After the expert review is completed, the final review result can be determined using the selected method on the Settings > Work > Review page.
    • By single reviewer: A GR is complete when one review expert approves or rejects it.
    • By all reviewers: A GR is complete when all review experts approve it or one review expert rejects it.
    • By pass rate: A GR is complete when "Number of review experts who approve the review/Total number of review experts × 100% ≥ Pass rate", or "Number of review experts who reject the review/Total number of review experts × 100% > 1 – Pass rate".
    If a GR's result in the review phase is Rejected, the GR skips the decision-making phase and its final result is Rejected.
  6. Click the title of a GR in the To Be Approved state. The GR details page is displayed on the right.
  7. On the details page, click Decide by reviewer in the upper right corner. In the displayed dialog box, set the required parameters.
    Figure 2 Decision-making by reviewer
    Table 4 Decision-making by reviewer
    Result
    Select your decision.
    • Transfer to others: Transfer the review to another reviewer.
    Comments
    Review Result
    The result of the review phase for your reference.
    Expert Comments
    Results and comments of review experts in the review phase for your reference.
  8. Select Approve or Reject for Result, and click OK. The GR status changes to End.
