Managing Bugs
After creating bugs (see Creating a Bug), you can query, import, export, and batch edit them in the project. You can add tags and associate work items on their details pages.
Operation |
Procedure |
Search for bug |
Import work items |
Use a template to import bugs in batches.
Export work items |
Export bugs in batches to an Excel file.
Configure fields to display |
Click next to the Operation field.
Clone bugs across projects |
Transition statuses in batches |
Perform batch operations |
You can select multiple bugs to perform operations in batches: edit, suspend/unsuspend, export, delete, cross-project clone, and transition. |
Group bugs |
You can group work items by any supported field type.
Operation |
Procedure |
Remarks |
Edit work item |
On the bug details page, click the value box of the field to be modified, and enter a target value in the text box or select one from the drop-down list. The modification is saved automatically. |
You must have permission to edit bugs. |
Change work item status |
Go to the work item details page, click the Status field, and transition the work item to the target status. For details about status transition, see Table 1. |
You must have permission to update statuses for bugs. |
Upload attachment |
Attachments can be pictures, workbooks, manuscripts, and text files. A maximum of 100 attachments can be added to each work item, and their total size cannot exceed 500 MB.
You must have permission to edit or upload attachments for bugs. |
Add and check related item |
A work item can be associated with other types of work items in a project.
You must have permission to associate/dissociate work items, associate/dissociate files, and associate/dissociate wikis for bugs. |
Add workload |
You must have permission to add person-hours for bugs. Workloads can be edited and deleted by the creator. By default, the project administrator can edit and delete all workloads. |
View operation history |
History displays all operation logs of users, including creation, status transition, review initiation, work item association, and workload addition.
You must have permission to view bugs. |
Tag work item |
Add comment |
