- What's New
- Function Overview
Service Overview
- What Is CodeArts Req?
- Advantages
- Use Cases
Features
- Multiple Built-in IPD Requirement Models
- E2E Traceability
- Baseline Management and Change Review
- Efficient Cross-Project Requirement Collaboration
- System Feature Management
- Customers' Raw Requirements Management
- Bug Full Lifecycle Management
- Efficient Cross-Organization Collaboration for Bug Tracking and Management
- Bug Trend Analysis and Quality Measurement
- Traceable Fixing Process
- Customizable Fixing Process
- Security
- Permission Management
- Constraints
- Getting Started
User Guide
- CodeArts Req Usage Process
- Purchasing and Authorizing CodeArts Req
- Accessing the CodeArts Req Homepage
- Creating a CodeArts Project
- Managing Scrum Project Requirements
Managing IPD-System Device Project Requirements
- Requirement Management Process
Configuring Common Settings
- Configuring Common Work Item Fields
- Configuring Common Work Item Statuses
- Configuring Work Item Templates
- Configuring Work Item Status Flows
- Configuring Work Item Tags
- Creating Work Item Modules
- Creating Work Types
- Configuring Work Item Status Roll-up Rules
- Configuring Notification Rules
- Viewing Work Item Import/Export Records
- Creating and Managing RRs
- Creating and Managing a Feature Tree and System Features
- Configuring Project Plans
- Creating and Managing R&D Requirements
- Creating and Managing Tasks
- Creating and Managing Bugs
- Reviewing Work Items
- Tracking the Project Progress
Managing IPD-Standalone Software Project Requirements
Common Configuration Management
- Configuring Automatic Roll-up Rules
- Configuring Notifications
- Configuring a Plan
- (Optional) Checking Audit Logs
Best Practices
- CodeArts Req Best Practices
- Best Practices of Scrum Projects
- Using IPD-System Device Projects to Manage RRs of a Smart Watch R&D Project
- Using IPD-System Device Projects to Manage Defects of a Smart Watch R&D Project
- Using IPD-System Device Projects to Perform a Baseline Review (BR) on a Smart Watch R&D Project
- Using IPD-System Device Projects to Manage Feature Trees of a Smart Watch R&D Project
- Huawei E2E DevOps Practice: Managing Requirements
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
Work Items of the Scrum Project
- Creating a Customized Field for a Work Item Type
- Uploading an image
- Obtaining Work Item Completion Rate
- Obtaining Comments on a Specified Work Item
- Querying Labor Hours by User (Single Project)
- Querying Labor Hours by User (Multi-Project)
- Obtaining the Work Item History
- Create work items.
- Querying Work Items of a Project
- Advanced Query Work Item
- Deleting Work Items in Batches
- Querying Work Item Details
- Updating a Work Item
- Deleting a Work Item
- Obtains sub-work items.
- Querying Historical Records of All Work Items in a Project
- Querying the Work Item Transfer Configuration of a Scrum Project
- Creating a Work Item as a Fine-grained Permission User
- Queries the work items associated with the current work item.
- Queries the associated Wikis associated with the current work item.
- Queries the code submission records or branch creation records associated with the current work item.
- Querying Associated Wikis
- Querying Customized Fields of Scrum Work Items
- Downloading an Image
- Uploading an Attachment to a Work Item
- Iteration of the Scrum Project
- User Information
- Project members
- Project Information
- Project Indicators
- Project Statistics
- Modules of the Scrum Project
- Domain of the Scrum Project
- Scrum Project Statuses
- Application Examples
- Appendixes
- Change History
Work Items
- How Can I Assign One Scrum Project Work Item to Multiple Members?
- Why Is a Message Reporting Duplicate File Name Displayed During File Association in a Scrum Project?
- How Do I Handle the Verification Exceptions in the Number of Work Items Imported to an IPD Project?
- How Do I Modify the Recipient After an IPD Project Requirement Is Assigned?
- Member Management
Troubleshooting
- Why Is the Message "You have been invited to run projects with another account. Accept invitation" Displayed When Inviting Other Users to Join My Project in CodeArts Req?
- Why Can't I Create a Project Using "DevOps Full-Process"?
- Why Is a Message Indicating the Field Name Already Exists Displayed When Setting a Work Item Field in a Scrum Project?
Work Items
- Videos
Project creators or roles with the automation configuration permission can enable or disable automation rules as required to implement automatic parent-child status roll-up or status transfer. Once a rule is enabled, all work items and users in the project can trigger the rule.
An IPD-system device project is available, in which you have the Automation permission.
Constraints and Restrictions
- If all child work items of the parent item meet the configuration in the rule condition and the target status of the parent item is the status that supports transition, the rule is executed.
- If the parent item has any child work items that do not meet the rule condition, when the rule is triggered, a record indicating no operation performed is generated and the parent item status is not transitioned.
- If there is no parent item, when the rule is triggered, a record indicating that no operation is performed is generated and the parent item status is not transitioned.
- If the parent item transition status configured in the rule does not support transition, when the rule is triggered, a record indicating an execution error is generated and the parent item status is not transitioned.
- Access the CodeArts Req homepage.
- Access the project details page and choose Settings > Work Item > Automation. The Automation page is displayed.
- Click Automation Rules.
- Set Enable to enable or disable the configured rule.
For example, if the status rollup of SF work items is enabled, when you change the status of all child work items of an unfinished SF work item in the Work Item > Req > Feature Tree list to Completed, the status of the SF work item is automatically rolled up to Completed.
- Go to the work item list. The SF status is automatically updated to Completed, and an automation rule operation record is added to the History tab page.
