Updated on 2025-08-01 GMT+08:00
Creating Work Item Modules
  • You can add, modify, and delete work item modules in a project.
  • You can add submodules to a module.
  • When creating or editing a work item, you can specify the module to which the work item belongs.
  • Click before the module name and drag the module to adjust the module sequence.
An IPD-system device project is available, and you have permission to set modules for the project.
Creating a Module
  1. Access the CodeArts Req homepage.
  2. Go to a project and choose Settings > Work > Modules.
  3. Click Create.
    Figure 1 Creating a module
  4. Set Module, Description, and Owner.
    The module name must be unique in the system.
  5. Click OK.
  6. (Optional) Edit or delete a module, or add a submodule.
    • Click to edit the module.
    • Click to delete the module.
    • Click to add a submodule. Each module can have a maximum of three levels, for example, Module1 > Submodule01 > Submodule001.
      Figure 2 Adding a submodule
