Updated on 2025-11-07 GMT+08:00
Program Requirement Aggregation View
In the program requirement aggregation view, the program/project requirement data corresponding to all subnodes of a program can be displayed in the top-level program. Members of the top-level program can view all requirement data, facilitating requirement management.
Constraints and Restrictions
  • After the Aggregate sub-project switch is enabled, inline editing is not supported on the list page.
  • Currently, Aggregate sub-project is available only on the Raw Requirements, Feature Tree, R&D Requirements, Tasks, and Defects tab pages.
Managing the Program Aggregation View
  1. Access the Raw Requirements, Feature Tree, R&D Requirements, Tasks, and Defects tab pages of a program.
  2. Toggle on the Aggregate sub-project switch in the upper right corner to display the data of all subnodes in the current view. If you toggle off this switch, only the work items of the current program are displayed in the view, and inline editing is supported on the list page.
    Figure 1 Program requirement list
