Help Center/ CodeArts Pipeline/ User Guide/ Configuring a Pipeline/ Configuring Pipeline Notifications
Updated on 2025-10-10 GMT+08:00
Pipeline notifications inform users or systems about pipeline activities. Subscribing to specific events helps you stay updated on pipeline statuses and execution results. You can configure event notifications (pop-ups, emails, Feishu, WeCom, and DingTalk notifications) for a pipeline.
  • By default, only pop-up notifications will be sent.
  • WeCom, DingTalk, and Feishu notifications are available only in the AP-Singapore region.
Configuring Notifications from CodeArts Pipeline
You can configure pop-ups to inform creators, executors, and users who have favorited pipelines of pipeline events (deletion, failure, success, and updates).
  1. Access the CodeArts Pipeline homepage.
  2. On the pipeline list page, search for the target pipeline, click in the Operation column, and select Edit.
  3. Switch to the Notifications page.
  4. Enable From CodeArts Pipeline, and enable or disable notifications as needed.
    • You can click in the upper right corner of the CodeArts Pipeline homepage and check the notification messages in the Messages window.
    Figure 1 Configuring notifications from CodeArts Pipeline
  5. After the configuration, click Save. A message is displayed, indicating that the pipeline is saved successfully.
Configuring Email Notifications
You can configure email notifications to inform creators, executors, and users who favorite pipelines of pipeline activities (deletion, failure, success, and updates).
  4. Enable Email, and enable or disable notifications as needed.
    Figure 2 Configuring email notifications
Configuring WeCom Notifications
Push pipeline activities to WeCom.
  4. Enable WeCom and set parameters.
    Figure 3 Configuring WeCom notifications
    Table 1 Parameters of WeCom notifications
    URL
    Enter the URL of the WeCom robot notifications. The URL must start with http:// or https://, for example, https://xxxxx.
    Notify When
    Select the pipeline status to be notified: completed, failed, paused, suspended, and ignored.
    Content
    Select the content to be notified: Pipeline name, Execution description, Executor, Triggering information, Project name, Execution time, and Status.
    @user_id
    Enter the user IDs receiving notifications. Use commas (,) to separate multiple user IDs.
Configuring DingTalk Notifications
Push pipeline activities to DingTalk.
  4. Enable DingTalk and set parameters.
    Figure 4 Configuring DingTalk notifications
    Table 2 Parameters of DingTalk notifications
    URL
    Enter the URL of the DingTalk robot notifications. The URL must start with http:// or https://, for example, https://xxxxx.
    Notify When
    Content
    @user_id
    @Mobile Number
    Enter the mobile numbers receiving notifications. Use commas (,) to separate multiple numbers.
    Additional Signature
    (Optional) Enter this parameter only when you have enabled security settings for the DingTalk custom robot.
Configuring Feishu Notifications
Push pipeline activities to Feishu.
  4. Enable Feishu and set parameters.
    Figure 5 Configuring Feishu notifications
    Table 3 Parameters of Feishu notifications
    URL
    Enter the URL of the Feishu robot notifications. The URL must start with http:// or https://, for example, https://xxxxx.
    Notify When
    Content
    @user_id
    (Optional) Enter this parameter only when you have enabled security settings for the Feishu custom robot.
