Help Center/ Organizations/ User Guide/ Managing NCPs/ Modifying or Deleting an NCP
Updated on 2026-08-25 GMT+08:00
This section describes how to modify and delete a custom NCP.
Modifying an NCP
  1. Log in to the Organizations console as an organization administrator or using the management account.
  2. On the Policies page, click Network control policies.
  3. Locate the custom NCP you want to modify and click Modify in the Operation column. In the displayed dialog box, enter "Confirm" and click OK.
    Figure 1 Modifying an NCP
  4. On the displayed page, modify the policy name and description as needed, as shown in Figure 2.
    Figure 2 Modifying an NCP
  5. Modify the policy content as needed. You can use the statement editor to modify the policy syntax. For details, see NCP Syntax.
  6. Click Save. If the policy list is displayed, the NCP is updated successfully. If a message appears indicating incorrect policy content, modify the NCP syntax.
Deleting an NCP
An NCP that is attached to OUs or accounts cannot be deleted. To delete such an NCP, you need to detach it from the OUs or accounts first.
  3. Locate the target custom NCP and click Delete in the Operation column.
  4. Click OK in the displayed dialog box.
    Figure 3 Deleting an NCP
