- What's New
- Getting Started
User Guide
- Permissions Management
- Managing Organizations
- Managing OUs
- Managing Accounts
Managing SCPs
- Overview of an SCP
- Enabling or Disabling the SCP Type
- Creating an SCP
- Modifying or Deleting an SCP
- Attaching or Detaching an SCP
- Example SCPs
- System-defined SCPs
- Cloud Services for Using SCPs
- Regions for Using SCPs
Actions Supported by SCP-based Authorization
- Compute
- Storage
- Networking
- Containers
- Analytics
- Content Delivery & Edge Computing
- Databases
- Security & Compliance
- Internet of Things
- Middleware
- Developer Services
- Business Applications
- Simple Message Notification (SMN)
- Log Tank Service (LTS)
- Identity and Access Management (IAM)
- Security Token Service (STS)
- Resource Formation Service (RFS)
- IAM Identity Center
- Organizations
- Resource Access Manager (RAM)
- Enterprise Project Management Service (EPS)
- Tag Management Service (TMS)
- Config
- IAM Access Analyzer
- Cloud Trace Service (CTS)
- Resource Governance Center (RGC)
- Application Operations Management (AOM)
- Cloud Eye (CES)
- IAM Identity Broker
- User Support
- Migration
- Managing Tag Policies
- Managing Trusted Services
- Managing Tags
- CTS Auditing
- Adjusting Quotas
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Managing OUs
Managing Accounts
- Creating an account and adding it to your organization
- Creating an Account
- Listing Accounts in an Organization
- Closing an Account
- Getting Account Information
- Updating an Account
- Removing the Specified Account
- Moving an Account
- Inviting an Account to Join an Organization
- Querying Account Creation Requests in Specified State
- Querying Account Creation Status
- Querying CloseAccount Requests in Specified State
- Managing Invitations
- Managing Delegated Administrators
- Managing Policies
Managing Tags
- Listing Tags for the Specified Resource
- Adding Tags to the Specified Resource
- Removing Tags from the Specified Resource
- Listing Tags for the Specified Resource Type
- Adding Tags to the Specified Resource Type
- Deleting Tags with the Specified Key from the Specified Resource Type
- Querying Resource Instances by Resource Type and Tag
- Querying Number of Resource Instances by Resource Type and Tag
- Querying Resource Tags
- Others
- Appendixes
- Change History
- FAQs
Enabling or Disabling the Tag Policy Type
You can enable or disable the tag policy type from the organization' management account, but not from any delegated administrator.
Enabling the Tag Policy Type
Before you can create and attach tag policies to the OUs and accounts in your organization, you must enable the tag policy type. The only way to enable the tag policy type is by using the organization's management account.
- Log in to the management console as the organization administrator or using the management account, and navigate to the Organizations console.
- On the Policies page, click Enable in the Operation column of tag policies.
Figure 1 Enabling the tag policy type
- In the displayed dialog box, select the check box and click OK.
If you no longer want to use tag policies in your organization, you can disable the tag policy type only from the organization's management account.
- After the tag policy type is disabled in an organization, all tag policies are automatically detached from all OUs and accounts in the organization. However, the policies are not deleted.
- If you disable the tag policy type, attachments of tag policies to entities will be lost. If you later re-enable the tag policy type, you must use the management account to re-attach tag policies to the entities.
- On the Policies page, click Disable in the Operation column of tag policies.
Figure 2 Disabling the tag policy type
- Click OK in the displayed dialog box.
