Help Center/ Organizations/ User Guide/ Managing Tag Policies/ Attaching or Detaching a Tag Policy
Updated on 2026-07-24 GMT+08:00
A tag policy remains inactive after creation until you attach it to the root OU, a specific OU, or an account.
If a tag policy is no longer necessary, you can detach it from the root OU, OUs, or accounts. Once detached, the policy immediately ceases to take effect.
You can attach a tag policy to or detach it from the root OU, other OUs or accounts from the organization's management account.
  • You can attach up to 10 tag policies to an account.
  • You can attach or detach a tag policy from only the organization administrator, but not from a delegated administrator.
  • Tag policies are applied within 30 minutes after they are attached.
Attaching a Tag Policy
Method 1:
  1. Log in to Huawei Cloud as the organization administrator or using the management account, navigate to the Organizations console, and access the Organization page.
  2. Select the OU or account you want to attach a tag policy to.
  3. On the details page, click the Policies tab. On the page, expand Tag policies and click Attach.
  4. Select the tag policy you want to attach and click OK.
    Figure 1 Attaching a tag policy
Method 2:
  1. On the Organizations console, access the Policies page.
  2. Click Tag policies. The list of tag policies is displayed.
  3. Locate the tag policy you want to attach and click Attach in the Operation column. Then, select the OU or account you want to attach the policy to.
  4. Click OK.
    Figure 2 Attaching a tag policy
Method 1:
  2. Select the OU or account you want to detach a tag policy from.
  3. On the details page, click the Policies tab. On the page, expand Tag policies, locate the target tag policy and click Detach in the Operation column.
    Figure 3 Detaching a tag policy
  4. Click Detach in the displayed dialog box.
Method 2:
  3. Click the name of the target tag policy and click the Targets tab.
  4. Locate the OU or account that you want to detach the tag policy from and click Detach in the Operation column.
  5. Click OK.
    Figure 4 Detaching a tag policy
