Deleting a Tag
Deleting a Tag from the Root, OUs, or Accounts
The following describes how to delete a tag from the root, OUs, or accounts.
You delete tags from the root, OUs, and accounts in the same way. The following uses deleting a tag from an OU as an example.
- Log in to Huawei Cloud as the organization administrator or using the management account, navigate to the Organizations console, and access the Organization page.
- Select the OU whose tag you want to delete and click the Tags tab in the pane on the right.
- Locate the tag you want to delete and click Delete in the Operation column. Then, click OK in the displayed dialog box.
Figure 1 Deleting a tag
Deleting a Tag from a Policy
The following describes how to delete tags from custom SCPs and tag policies.
The procedures for deleting tags from custom SCPs and tag policies are similar. The following uses deleting a tag from a custom SCP as an example.
- Log in to the management console as the organization administrator or using the management account, and navigate to the Organizations console.
- On the Policies page, click Service control policies.
- Click the name of a policy to go to the policy details page.
- On the Tags page, locate the tag you want to delete and click Delete in the Operation column.
- Click OK in the displayed dialog box.
Figure 2 Deleting a tag
