Updated on 2025-06-25 GMT+08:00
Creating an OU
You can create an OU in your organization's root. OUs can be nested up to five levels deep.
To create an OU:
  1. Log in to Huawei Cloud as the organization administrator or using the management account, navigate to the Organizations console, and access the Organization page.
  2. Select the parent OU by clicking its name rather than the expand icon. If you are creating an OU for the first name, select the Root OU.
    OUs can be nested up to five levels deep. Each OU can have only one parent OU but can have many child OUs. When creating an OU, ensure that the parent OU you select is the upper-level one.
  3. Choose Add > Add Organizational Unit.
    Figure 1 Adding an OU
  4. In the displayed dialog box, enter the OU name.
  5. (Optional) Add a tag to the OU.
    A tag consists of a key-value pair. Tags are used to identify, classify, and search for OUs. A maximum of 20 tags can be added to an OU.
    Table 1 describes the key and value descriptions of a tag.
    Table 1 Tag description
    Element
    Example
    Tag key
    A tag key of an OU must be unique. You can create a custom key or select a key of an existing tag created in Tag Management Service (TMS).
    A tag key:
    • Cannot be an empty string.
    • Contains 1 to 128 characters.
    • Consists of letters, digits, underscores (_), hyphens (-), and Unicode characters (\u4E00-\u9FFF).
    Key_0001
    Tag value
    A tag value can be repetitive or an empty string.
    A tag value:
    • Can be an empty string.
    • Contains 1 to 225 characters.
    • Consists of letters, digits, underscores (_), periods (.), hyphens (-), and Unicode characters (\u4E00-\u9FFF).
    Value_0001
  6. Click OK.
