Managing a Migration Task Group
You can pause, resume, or restart tasks in a migration task group.
- Sign in to the OMS console.
 - In the navigation pane on the left, choose Migration Task Groups.
The Migration Task Groups page is displayed.
 - Manage a migration task group.
Table 1 Managing a migration task group Operation
Pausing a migration task group
A task group in the Creating status can be paused.
- Click Stop in the Operation column of the task group.
 - Read the content in the dialog box and click OK.
The task status changes to Paused.
Resuming a migration task group
You can resume a paused migration task group.
- Click Start in the Operation column of the task group.
 - In the displayed Resume Task Group dialog box, enter the source and destination AKs and SKs and click OK.
If CDN authentication is enabled, you need to enter the verification key.
The task status changes to Executing.
Restarting a migration task group
If any migration task in a group fails, the group enters the Failed status. You can restart the task group to retry the migration.
- Choose More > Restart in the Operation column of the task group.
 - In the displayed Restart Task Group dialog box, enter the source and destination AKs and SKs and click OK.
- If Failed Object Record is enabled, you need to set Migration Range. You can select All objects to migrate all the objects in the task group or select Failed objects to migrate only the objects that failed to be migrated.
 - If CDN authentication is enabled, you need to enter the verification key.
Deleting a migration task group
If you do not need to continue a migration or clear a completed migration task group, you can delete the task group when it is not in the Migrating status.
NOTE:If the task group you want to delete is in the Migrating status, pause and delete it.
Choose More > Delete in the Operation column of the task group.
The deleted migration task group will disappear from the list.
