On this page
Managing a Migration Task
Updated on 2024-12-19 GMT+08:00
You can pause, start, restart, or delete a migration task.
  1. Sign in to the console and go to the OMS page.
  2. Manage a migration task.
    Table 1 Managing a migration task
    Operation
    Pausing a migration task
    You can pause a migration task if the number of concurrent migration tasks exceeds what is supported. You can pause migration tasks less important to you so that the important migration tasks can be executed preferentially.
    1. Click Stop in the Operation column of the task.
    2. Read the content in the dialog box and click OK.
      The task status changes to Paused.
    Resuming a migration task
    You can resume a paused migration task.
    1. Click Start in the Operation column of the task.
    2. In the displayed Resume Task dialog box, enter the source and destination AK/SK pairs and click OK.
      If CDN authentication is enabled, you need to enter the verification key.
      The task status changes to Migrating.
    Restarting a migration task
    If a migration task fails, you can restart the task to perform the migration again.
    1. Choose More > Restart in the Operation column of the task.
    2. In the displayed Restart Task dialog box, enter the source and destination AKs and SKs and click OK.
      • If Failed Object Record is enabled, you need to set Migration Range. You can select All objects to migrate all the objects in the migration task or selects Failed objects to migrate only the object that failed to be migrated.
      • If CDN authentication is enabled, you need to enter the verification key.
    Deleting a migration task
    If you do not need to continue a migration or clear a completed migration task, you can delete the task when it is not in the Migrating status.
    If the task you want to delete is in the Migrating status, pause and delete it.
    Choose More > Delete in the Operation column of the task.
    The deleted migration task will disappear from the task list.
