Dedicated Data
Updated on 2024-11-18 GMT+08:00
What Is Dedicated Data?
If you configure dedicated data for your IoT SIM cards, they can only access preset platforms or systems. You can configure dedicated data with fixed addresses, including fixed domain names and fixed IP addresses.
A fixed domain name or IP address is required for dedicated data.
Configuration Rules
Currently, dedicated data can be configured only for IoT SIM cards of China Telecom, China Mobile, and China Unicom.
Configuration rules of different carriers:
  • Do not directly use the content of the Fixed Address (Only for Reference) column in the table. Set the fixed address based on the site requirements.
  • The wildcard character (*) indicates any characters. For example, the domain name https://*.example.com includes https://www.example.com, https://a.example.com, and https://b.example.com. The wildcard character (*) can be used only once in a domain name.
  • China Telecom: Up to 10 fixed addresses. Five IP addresses at most. Wildcard characters are allowed only for domain names. Your request will be processed within five working days. Example:
    Type
    Protocol
    Wildcard Supported
    Port
    Domain name
    HTTP
    Yes
    http://www.*.example.com:80
    Optional (default value: 80)
    Domain name
    HTTPS
    No
    https://www.example.com:443
    Optional (default value: 443)
    Domain name
    UDP or TCP
    No
    tcp://example.com
    Optional
    Domain name
    Yes
    mqtt://*.example.com
    Optional
    IP
    127.0.0.1
  • China Unicom: Up to 10 fixed addresses. "/*" is the default end of an HTTP domain name. Addresses using HTTP and HTTPS protocols support wildcard characters. Your request will be processed within seven working days. Example:
    Type
    Protocol
    Wildcard Supported
    Port
    Domain name
    HTTP
    No
    http://www.example.com
    Optional
    Domain name
    HTTPS
    Yes
    Domain name
    TCP or UDP
    tcp://example.com
    Optional
    Domain name
    mqtt://example.com
    Optional
    IP
    127.0.0.1
    Optional
  • China Mobile: Configure up to 10 fixed addresses. Wildcard characters are allowed only for domain names. Your request will be processed within six weeks. Example:
    Type
    Protocol
    Wildcard Supported
    Port
    Domain name
    HTTP
    No
    Optional
    Domain name
    HTTPS
    Yes
    https://www.*.example.com
    Optional
    Domain name
    UDP or TCP
    Yes
    tcp://*.example.com
    Optional
    Domain name
    No
    mqtt://example.com
    Optional
    IP
    127.0.0.1
Configuring a Fixed Domain Name/IP Address
  • If invalid fixed addresses are configured, the corresponding cards may fail to use data. You are advised to configure fixed addresses for a small number of test cards at first and then for all cards.
  • Configure fixed addresses under the guidance of technical personnel. If you encounter any problem during the configuration, contact Huawei technical support.
  • Fixed address is only available for physical SIM cards of a card purchase/transfer order with dedicated data.
  1. Log in to the GSL console.
  2. In the navigation pane, choose Orders and Renewal.
  3. Click the target batch number to access the Order Details page.
  4. On the Fixed Address Info tab page in the lower part of the page, you can add, modify, or delete fixed addresses.
    You can click Add Historical Fixed Address to select an existing target fixed address.
    • Adding a fixed address
      Click Add Fixed Address. In the displayed dialog box, configure the fixed address by referring to Configuration Rules.
      Figure 1 Adding fixed domain name
    • Modifying a fixed address
      Locate the target fixed address and click Modify in the Operation column to modify the fixed address.
      A fixed address in the Configuring, Reviewing, or Deleting status cannot be modified.
    • Deleting a fixed address
      Locate the target fixed address and click Delete in the Operation column to delete the fixed address.
      • A fixed address in the Configuring or Reviewing status cannot be deleted.
      • Orders configured with dedicated data must retain at least one fixed address.
