Custom Attributes
You can use custom attributes to add remarks to SIM cards. You can add, modify, enable, and disable custom attributes and set these attributes for SIM cards.
Precautions
- A user can create up to six custom attributes.
- Only enabled custom attributes can be edited and displayed on the SIM card list page.
Adding a Custom Attribute
- Log in to the GSL console.
- In the navigation pane, choose Custom Attributes.
- Click Add Custom Attribute.
- In the displayed dialog box, set the custom attribute name.
Enter up to 32 characters, including digits, letters, underscores (_), and hyphens (-). The new name must be unique.
- Click Submit.
Managing Custom Attributes
You can disable, enable, or modify an existing custom attribute.
- Perform the following operations as required.
- Disabling a custom attribute
Click Disable in the Operation column of the target attribute. The disabling is successful when the Status becomes Disabled.
- Enabling a custom attribute
Click Enable in the Operation column of the target disabled attribute. The enabling is successful when the Status becomes Enabled.
- Modifying a custom attribute
Click Modify in the Operation column of the target attribute. In the displayed dialog box, change the custom attribute name and click Submit.
