Dashboard
Log in to the GSL console, you can view the overall information about SIM cards and devices on the Dashboard page.
- SIM card status
SIM Card Status records the number of SIM cards in total and in different lifecycle status. The lifecycle statuses of a SIM card are described in the following table.
Status
Activatable
The SIM card has subscribed to a plan but has not been used.
In use
The SIM card has subscribed to a plan and is in use.
Suspended
The plan data of the SIM card is used up or the SIM card is manually suspended.
Deregistered
The SIM card is deregistered after being suspended.
- Data statistics
You can view Data Usage Warning, Plan Expiration Statistics, Data Usage Trend (Last 30 Days), and Card Rankings by Data Usage This Month. Click a statistical item to check the list of SIM cards that meet the conditions.
- Order status
You can view the number of orders in different statuses, including Reviewing, Approved, To Be Shipped (Renewing), Shipped, Completed, Canceled (not applicable to physical SIM cards), Failed, Rejected, Processing, and Unsubscribed. Click a statistical item to check the list of orders that meet the conditions.
- Request status
You can trace the request progress of various operations, including card suspension and resumption, batch suspension and resumption, batch transfer or activation of physical SIM cards (for all or specified cards), and creation of a data pool.
You can view the number of requests in different statuses, including Reviewing, Approved, Processing, Completed, Canceled, Failed, and Rejected. Click a statistical item to check the list of requests that meet the conditions.
