EG-based Event Notifications
You can configure EventGrid (EG) event notifications to promptly detect operations on a bucket and its objects and trigger follow-up actions.
For example, you can define an EG event notification that automatically adds watermarks to images uploaded to a specific bucket and stores the watermarked images in a target bucket.
How OBS Works with EG
OBS stores objects such as files, images, and videos. Uploading, modifying, or deleting these objects generate OBS events. After capturing the OBS events, EG automatically triggers follow-up actions or processes based on the predefined rules. In this process, OBS sends notifications, and EG delivers tasks, removing the need for manual intervention.
An EG event notification rule consists of an event source, channel, and event target:
- Event source: a source that generates events. For a cloud service, there will be events when users send requests to it.
- Channel: a transfer station that receives events from cloud services
- Event target: a destination that processes events. Cloud service events from the channel can trigger other cloud services to perform actions. (For example, FunctionGraph can be triggered to add watermarks to images and store the images in OBS buckets.)
Figure 1 shows how OBS works with EG.
The following describes how OBS works with EG in detail:
- An administrator creates an EG notification rule that includes the event source, channel, and event target.
- When the administrator or other users perform operations on objects in OBS buckets, OBS events are generated.
- EG pushes the events to the event target through the channel. The event target then triggers other cloud services to perform follow-up operations.
Supported OBS Event Types
EG notifications support two types of OBS event sources: OBS Application Service and Object Storage Service (OBS).
- OBS Application Service: this source pushes events for specific operations performed on objects in OBS buckets
- Object Storage Service (OBS): this source pushes audit log events for operations performed on OBS buckets and objects and operations triggered by the system itself
| OBS Event Source Type | EG Event Type | Description |
| OBS Application Service | OBS:DWR:ObjectCreated:PUT | Uploading an object using PUT |
| OBS:DWR:ObjectCreated:POST | Uploading an object using POST | |
| OBS:DWR:ObjectCreated:COPY | Copying an object | |
| OBS:DWR:ObjectCreated:CompleteMultipartUpload | Assembling parts in a multipart upload | |
| Object Storage Service (OBS) | OBS:CloudTrace:ApiCall | Audit log events for operations triggered by API Gateway calls |
| OBS:CloudTrace:ObsSDK | Audit log events for OBS bucket operations triggered by OBS SDK calls | |
| OBS:CloudTrace:ConsoleAction | Audit log events for operations performed on the console | |
| OBS:CloudTrace:SystemAction | Audit log events for operations triggered by the system itself | |
| OBS:CloudTrace:Others | Audit log events for operations except those on OBS buckets triggered by OBS SDK calls |
Structure of the Event Notification Messages Sent by OBS
Once there is an OBS event, OBS sends an event notification message in a fixed JSON structure to EG. After receiving the notification, EG triggers other cloud services to perform actions.
The following gives an example of the JSON notification message OBS sends to EG:
channel_id: "a1b2c3d4e5f678901234567890abcdef",
events: [
specversion: "1.0",
source: "HC.OBS.DWR",
type: "OBS:DWR:ObjectCreated:PUT",
datacontenttype: "application/json",
dataschema: "",
subject: "exampleobject",
time: "Fri, 04 Jul 2025 06:08:01 GMT",
ttl: "4000",
data: {
eventVersion: "3.0",
eventSource: "OBS",
eventRegion: "cn-east-3",
eventTime: "2025-7-04T06:08:01.957Z",
eventName: "ObjectCreated:PUT",
userIdentity: {
requestParameters: {
sourceIPAddress: "x.x.x.x"
responseElements: {
x-obs-request-id: "000001980D3CC5B5024FE333FEB97E7F",
x-obs-id-2: "",
obs: {
Version: "1.0",
configurationId: "test-trigger",
bucket: {
ownerIdentity: {
bucket: "examplebucket"
object: {
key: "exampleobject",
eTag: "65a8e27d8879283831b664bd8b7f0ad4",
versionId: 9876543210987654321,
sequencer: "1",
oldpsxpth: ""
} The following table describes the fields that the message includes.
| Field | Description |
| channel_id | The unique identifier of the EG event channel |
| events[].specversion | The version of the EG event specification |
| events[].id | The unique identifier of the EG event |
| events[].source | The service name of the EG event source. The value is always HC.OBS.DWR. |
| events[].type | The EG event type, which is a character string separated by commas (,) |
| events[].datacontenttype | The content type of the EG event data. The value is always application/json. |
| events[].dataschema | The schema of the EG event data |
| events[].subject | The object name |
| events[].time | The UTC time when the EG event occurs |
| events[].ttl | How long the EG event remains valid. The default value is 4 seconds. |
| events[].data.eventVersion | The version of the OBS message |
| events[].data.eventSource | The message source. The value is always OBS. |
| events[].data.eventRegion | The region where the event occurs |
| events[].data.eventTime | The event time in ISO-8601 format |
| events[].data.eventName | The name of the event that triggers the notification |
| events[].data.userIdentity.ID | The billing ID of the user who triggers the event |
| events[].data.requestParameters.sourceIPAddress | The request's source IP address |
| events[].data.responseElements.x-obs-request-id | The request ID |
| events[].data.responseElements.x-obs-id-2 | The special symbols that help locate problems |
| events[].data.obs.Version | The OBS version |
| events[].data.obs.configurationId | The name of the OBS event trigger that matches the event |
| events[].data.obs.bucket.name | The bucket name |
| events[].data.obs.bucket.ownerIdentity.ID | The account ID of the bucket owner |
| events[].data.obs.object.key | The object name |
| events[].data.obs.object.eTag | The object ETag |
| events[].data.obs.object.size | The object size |
| events[].data.obs.object.versionId | The object version ID |
| events[].data.obs.object.sequencer | The identifier that determines the sequence of a specific object event |
| events[].data.obs.object.oldpsxpth | The path of the file before being renamed in the parallel file system |
- Object upload
{ channel_id: "a1b2c3d4e5f678901234567890abcdef", events: [ { specversion: "1.0", id: "17793124-84s5-5e1c-9s20-8fes5s8b54wf", source: "HC.OBS.DWR", type: "OBS:DWR:ObjectCreated:PUT", datacontenttype: "application/json", dataschema: "", subject: "exampleobject", time: "Fri, 04 Jul 2025 06:08:01 GMT", ttl: "4000", data: { eventVersion: "3.0", eventSource: "OBS", eventRegion: "cn-east-3", eventTime: "2025-7-04T06:08:01.957Z", eventName: "ObjectCreated:PUT", userIdentity: { ID: "08b4efe0fc00d3ce0f17c01b948f6e80" }, requestParameters: { sourceIPAddress: "x.x.x.x" }, responseElements: { x-obs-request-id: "000001980D3CC5B5024FE333FEB97E7F", x-obs-id-2: "", }, obs: { Version: "1.0", configurationId: "test-trigger", bucket: { name: "examplebucket", ownerIdentity: { ID: "08b4efe0fc00d3ce0f17c01b948f6e80", }, bucket: "examplebucket" }, object: { key: "exampleobject", eTag: "65a8e27d8879283831b664bd8b7f0ad4", size: "1024", versionId: 9876543210987654321, sequencer: "1", oldpsxpth: "" } } } }, ] } - Manual object deletion
{ channel_id: "a1b2c3d4e5f678901234567890abcdef", events: [ { specversion: "1.0", id: "17793124-84s5-5e1c-9s20-8fes5s8b54wf", source: "HC.OBS.DWR", type: "OBS:DWR:ObjectRemoved:Delete", datacontenttype: "application/json", dataschema: "", subject: "exampleobject", time: "Fri, 04 Jul 2025 06:08:01 GMT", ttl: "4000", data: { eventVersion: "3.0", eventSource: "OBS", eventRegion: "cn-east-3", eventTime: "2025-7-04T06:08:01.957Z", eventName: "ObjectRemoved:Delete", userIdentity: { ID: "08b4efe0fc00d3ce0f17c01b948f6e80" }, requestParameters: { sourceIPAddress: "x.x.x.x" }, responseElements: { x-obs-request-id: "000001980D3CC5B5024FE333FEB97E7F", x-obs-id-2: "", }, obs: { Version: "1.0", configurationId: "test-trigger", bucket: { name: "examplebucket", ownerIdentity: { ID: "08b4efe0fc00d3ce0f17c01b948f6e80", }, bucket: "examplebucket" }, object: { key: "exampleobject", eTag: "65a8e27d8879283831b664bd8b7f0ad4", size: "1024", versionId: 9876543210987654321, sequencer: "1", oldpsxpth: "" } } } }, ] } - Object deletion using a lifecycle rule
| Category | Description |
| OBS buckets |
| Permissions | If you select OBS Application Service as the event source, your account must have the Tenant Administrator permission. For details, see Assigning Dependency Roles. |
| Accounts | Currently, federated accounts cannot use EG notifications. |
| Creation of EG notification rules |
| Edit of EG notification rules |
Billing for EG Notifications
You need to pay for using EG. For details, see EG Billing.
- You have enabled EG and your account or IAM user has the EG FullAccess permission.
- Your Huawei account or IAM user has the Tenant Administrator permission. For details, see Using IAM to Grant Access to OBS.
Creating an EG Notification Rule
You can use OBS Console to create EG notification rules.
Disabling, Enabling, Modifying, or Deleting EG Notification Rules
You can use OBS Console to disable, enable, modify, or delete EG notification rules.
Exporting EG Notification Rules
You can use OBS Console to export EG notification rules.
