Updated on 2026-09-10 GMT+08:00
Checking the Upload Progress
You can use OBS SDKs to obtain the upload progress of a specified object to estimate the remaining time.
SDKs Available for Progress Check
You can use the SDKs listed below to check your upload progress.
Java
Python
C: not supported
Go: not supported
BrowserJS
.NET
Android
iOS: not supported
PHP: not supported
Node.js: not supported
