- What's New
- Getting Started
- User Guide
- User Guide (Staking Nodes)
Developer Guide
Ethereum Node Engine
- Introduction
- JSON-RPC API Request Examples
- Application Development
- Smart Contract Development
Ethereum APIs
- Dedicated Edition
Shared Edition
- eth_blocknumber
- eth_getBlockByNumber
- eth_getUncleByBlockNumberAndIndex
- eth_getUncleByBlockHashAndIndex
- eth_getUncleCountByBlockNumber
- eth_getUncleCountByBlockHash
- eth_getBlockByHash
- eth_getTransactionByHash
- eth_getTransactionCount
- eth_getTransactionByBlockHashAndIndex
- eth_getTransactionByBlockNumberAndIndex
- eth_getBlockTransactionCountByHash
- eth_getBlockTransactionCountByNumber
- eth_getTransactionReceipt
- eth_sendRawTransaction
- eth_call
- eth_createAccessList
- eth_estimateGas
- eth_feeHistory
- eth_maxPriorityFeePerGas
- eth_gasPrice
- eth_getBalance
- eth_subscribe
- eth_unsubscribe
- eth_getStorageAt
- eth_getCode
- eth_getProof
- eth_getLogs
- eth_getFilterChanges
- eth_getFilterLogs
- eth_newBlockFilter
- eth_newFilter
- eth_newPendingTransactionFilter
- eth_uninstallFilter
- eth_chainId
- web3_sha3
- web3_clientVersion
- net_version
- net_listening
- TRON Node Engine
Polygon PoS
- Polygon PoS Introduction
- HTTP Request Examples
- WebSocket Request Examples
Polygon PoS APIs
- Dedicated Edition
Shared Edition
Ethereum JSON-RPC APIs
- eth_blocknumber
- eth_getTransactionReceiptsByBlock
- eth_call
- eth_estimateGas
- eth_feeHistory
- eth_gasPrice
- eth_getBalance
- eth_getRootHash
- eth_subscribe
- eth_unsubscribe
- eth_getStorageAt
- eth_accounts
- eth_getCode
- eth_getProof
- eth_getLogs
- eth_getFilterLogs
- eth_newFilter
- eth_chainId
- web3_sha3
- Polygon JSON-RPC APIs
Arbitrum
- Arbitrum Introduction
Arbitrum APIs
Shared Edition
- eth_blocknumber
- eth_syncing
- eth_call
- eth_estimateGas
- eth_feeHistory
- eth_gasPrice
- eth_getBalance
- eth_subscribe
- eth_unsubscribe
- eth_getStorageAt
- eth_accounts
- eth_getCode
- eth_getProof
- eth_getLogs
- eth_getFilterLogs
- eth_newFilter
- eth_chainId
- web3_sha3
Shared Edition
BNB Smart Chain
- BNB Smart Chain Introduction
BNB Smart Chain APIs
- Dedicated Edition
Shared Edition
- eth_blocknumber
- eth_hashrate
- eth_syncing
- eth_call
- eth_mining
- eth_estimateGas
- eth_feeHistory
- eth_gasPrice
- eth_getBalance
- eth_subscribe
- eth_unsubscribe
- eth_getStorageAt
- eth_accounts
- eth_getCode
- eth_getProof
- eth_getLogs
- eth_getFilterLogs
- eth_newFilter
- eth_chainId
- web3_sha3
- txpool_status
- net_listening
- net_version
- Batch Requests
- API Reference
APIs
- How Do I Determine Whether Flow Control Is Triggered for an API?
- What Are the Flow Control Policies for Full Nodes?
- How Many Methods Can Be Included in a JSON-RPC Batch Request for the Dedicated Version?
- How Many WebSocket Connections Can Be Made Each Time?
- How Do I Use HTTP Endpoints and Authentication Credentials to Access Nodes?
- Staking Nodes
APIs
Show all
Custom Policies
Custom policies can be created to supplement the system-defined policies of NES.
You can create custom policies in either of the following ways:
- Visual editor: Select cloud services, actions, resources, and request conditions. This does not require knowledge of policy syntax.
- JSON: Create a policy in the JSON format from scratch or based on an existing policy.
For details, see Creating a Custom Policy. The following section contains examples of common NES custom policies.
- On the management console homepage, click Identity and Access Management.
- In the navigation pane, choose Permissions > Policies/Roles and click Create Custom Policy.
- On the Create Custom Policy page, set the policy name, view, content, and description, then click OK.
- Policy Name: Enter a custom policy name, for example, partial NES permissions.
- Policy View: Select JSON.
- Policy Content: Enter the policy content based on the template.
For example, to create a node, query a single node, and obtain node monitoring information, copy the following content:
{ "Version": "1.1", "Statement": [ { "Action": [ "bcs:nesNode:create", "bcs:nesNode:get", "bcs:nesNode:getMetric" ], "Effect": "Allow" } ] }
Table 1 Policy content parameters Parameter
Value
Version
Policy version
Fixed to 1.1.
Statement
Effect
Whether the actions are allowed
- Allow
- Deny
Action
Operations to be performed on NES
Each action name is in the format of Service name:Resource type:Operation and cannot be customized. Table 2 lists the fine-grained permissions supported by NES. After you set any action, the permissions for the action will be granted to the IAM user.
Table 2 Action description Action
Action Description
bcs:nes:getSummary
Obtaining the Overview Information
bcs:nes:listNetwork
Obtaining the Network Types
bcs:nes:listNetworkFlavor
Obtaining Available Specifications
bcs:nesNode:listFlavor
Obtaining Available Specifications for Node Scaling
bcs:nesNode:list
Obtaining All Nodes on a Specified Network
bcs:nesNode:create
Creating a Node
bcs:nesNode:get
Querying a Node
bcs:nesNode:delete
Deleting a Node
bcs:nesNode:update
Updating a Node
Obtaining the Node Monitoring Information
bcs:nesNode:getStatistic
Obtaining the API Calling Information of a Node in a Specified Period
bcs:nesNode:getStatus
Obtaining the Status of a Staking Node in a Specified Period
bcs:nesNode:downloadCert
Downloading Certificates
bcs:nesAPIKey:create
Creating an API Key
bcs:nesAPIKey:list
Obtaining All API Keys of a User
bcs:nesAPIKey:delete
Deleting an API Key
bcs:nesAPIKey:update
Updating an API Key
bcs:nesNode:validateRelays
Verifying the Address of Relays
bcs:nesNode:updateRelays
Updating the Address of Relays
