- What's New
- Function Overview
- Billing
Getting Started
- Using a Public NAT Gateway to Enable Servers to Share One or More EIPs to Access the Internet
- Using a Public NAT Gateway to Enable Servers to Be Accessed by the Internet
- Using a Private NAT Gateway to Connect Cloud and On-premises Networks
- Using Multiple Public NAT Gateways Together in Performance-Demanding Scenarios
User Guide
- Public NAT Gateways
- Private NAT Gateways
- Permissions Management
- Tag Management
- Managing Quotas
- Monitoring
- Auditing
Best Practices
- Enabling Private Networks to Access the Internet Using a Cloud Connection and SNAT
- Using a Public NAT Gateway and Direct Connect to Accelerate Internet Access
- Using a Private NAT Gateway and Direct Connect to Enable Communications Between a VPC and an On-premises Data Center
- Using a Public NAT Gateway and VPC Peering to Enable Communications Between VPCs and the Internet
- Preserving Your Network with NAT Gateways During Cloud Migration
API Reference
- Before You Start
- API Overview
- Calling APIs
- APIs of Public NAT Gateways
- APIs for Private NAT Gateways
- Application Examples
- Appendixes
- Out-of-Date APIs
- SDK Reference
Public NAT Gateways
- What Is the Relationship Between a VPC, Public NAT Gateway, EIP Bandwidth, and ECS?
- How Does a Public NAT Gateway Offer High Availability?
- Which Ports Cannot Be Accessed?
- What Are the Differences Between Using a Public NAT Gateway and Using an EIP for an ECS?
- What Should I Do If I Fail to Access the Internet Through a Public NAT Gateway?
- Can I Change the VPC for a Public NAT Gateway?
- Does Public NAT Gateway Support IPv6 Addresses?
- What Security Policies Can I Configure to Implement Access Control If I Use a Public NAT Gateway?
- What Can I Do If Connection Between My Servers and the Internet Fails After I Add SNAT and DNAT Rules?
- Can a Public NAT Gateway Limit the Bandwidth of a Server?
- What Can I Do If the Number of Lost Packets of a Public NAT Gateway Exceeds the Threshold (or EIP Port Allocation Exceeds the Threshold)?
- How Do I Troubleshoot a Network Failure After a Private NAT Gateway Is Configured?
- How Many Private NAT Gateways Can I Buy in a VPC?
- Can I Increase the Numbers of SNAT and DNAT Rules Supported by a Private NAT Gateway?
- Can Private NAT Gateways Translate On-premises IP Addresses Connected to the Cloud Through Direct Connect?
- What Are the Differences Between Private NAT Gateways and Public NAT Gateways?
- Can a Private NAT Gateway Be Used Across Accounts?
SNAT Rules
- Why Do I Need SNAT?
- What Are SNAT Connections?
- What Is the Bandwidth of a Public NAT Gateway That Is Used by Servers to Access the Internet? How Do I Configure the Bandwidth?
- How Do I Resolve Packet Loss or Connection Failure Issues When Using a NAT Gateway?
- What Should I Do If My ECS Fails to Access a Server on the Public Network Through a Public NAT Gateway?
- What Are the Relationships and Differences Between the CIDR Blocks in a NAT Gateway and in an SNAT Rule?
- DNAT Rules
Public NAT Gateways
- Videos
- Glossary
More Documents
- Overview
- Getting Started
- Managing NAT Gateways
- Managing SNAT Rules
- Managing DNAT Rules
- Monitoring Management
- What Is the Relationship Between VPC, NAT Gateway, EIP Bandwidth, and ECS?
- How Does A NAT Gateway Offer High Availability?
- What Can I Do If I Fail to Access the Internet Through the NAT Gateway?
- Can I Change the VPC for a NAT Gateway After It Is Created?
- What Is the Quota of the NAT Gateway?
SNAT
- Why SNAT Is Used?
- What Is the Bandwidth of the NAT Gateway When a Server Accesses the Internet Through the NAT Gateway? Where Can I Configure the Bandwidth?
- DNAT
- Change History
- API Reference (ME-Abu Dhabi Region)
User Guide (Paris Region)
- Overview
Getting Started
- Allowing a Private Network to Access the Internet Using SNAT
- Allowing Internet Users to Access a Service in a Private Network Using DNAT
- Allowing On-Premises Servers to Communicate with the Internet
- Using Private NAT Gateways to Enable Communications Between Cloud and On-premises Networks
- Monitoring
Public NAT Gateways
- What Are the Differences Between Using a NAT Gateway and Using an EIP for an ECS?
- What Should I Do If I Fail to Access the Internet Through a NAT Gateway?
- Can I Change the VPC for a NAT Gateway?
- Can I Update NAT Gateways and SNAT Rules?
- Does NAT Gateway Support IPv6 Addresses?
- What Security Policies Can I Configure to Implement Access Control If I Use a NAT Gateway?
- How Many Private NAT Gateways Can I Create in a VPC?
- Can an SNAT Rule and a DNAT Rule of a Private NAT Gateway Share the Same Transit IP Address?
- Can a Private NAT Gateway Be Used Across ?
SNAT Rules
- What Is the Bandwidth of a NAT Gateway That Is Used by Servers to Access the Internet? How Do I Configure the Bandwidth?
- What Should I Do If My ECS Fails to Access a Server on the Public Network Through a NAT Gateway?
- DNAT Rules
Public NAT Gateways
- Change History
- API Reference (Paris Region)
- Overview
- Getting Started
- NAT Gateway
SNAT
- Why Is SNAT Used?
- DNAT
- Change History
- API Reference (Kuala Lumpur Region)
User Guide (Ankara Region)
- Getting Started
- Monitoring
- SNAT Rules
- DNAT Rules
- Change History
API Reference (Ankara Region)
- Before You Start
- API Overview
- Calling APIs
- APIs for Public NAT Gateways
- Private Nat API
- Common Parameters
- Change History
Adding a DNAT Rule
After a public NAT gateway is created, add DNAT rules to allow servers in your VPC to provide services accessible from the Internet.
Only one DNAT rule can be configured for each port on a server. One port can be mapped to only one EIP. If multiple servers need to provide services accessible from the Internet, create multiple DNAT rules.
Restrictions and Limitations
- Only one DNAT rule can be configured for each port on a server. One port can be mapped to only one EIP.
- A maximum of 200 DNAT rules can be added on a public NAT gateway.
- Go to the public NAT gateway list page.
- On the displayed page, click the name of the public NAT gateway on which you need to add a DNAT rule.
- On the public NAT gateway details page, click the DNAT Rules tab.
- Click Add DNAT Rule.
Figure 1 Add DNAT Rule
- Configure required parameters. For details, see Table 1.
Table 1 Descriptions of DNAT rule parameters Parameter
Select VPC if your servers in a VPC will use the DNAT rule to share the same EIP to provide services accessible from the Internet.
Direct Connect/Cloud Connect: Select this scenario if your on-premises servers or servers in another VPC will use the DNAT rule to provide services accessible from the Internet.
Port Type
The port type
- All ports: All requests received by the gateway through all ports over any protocol will be forwarded to the private IP address of your server.
- Specific port: Only requests received from a specified port over a specified protocol will be forwarded to the specified port on the server.
Protocol
The protocol can be TCP or UDP.
This parameter is available if you select Specific port for Port Type. If you select All ports, the value of this parameter is All by default.
Public IP Address Type
The type of the public IP address used for accessing the Internet
EIP: You can select an EIP that has not been bound to any resource or has been bound to a DNAT rule in the current VPC.
Global EIP: You can select an unused global EIP or a global EIP that is in use by a DNAT rule of the current NAT gateway.
Public Port
The port of the EIP used by the NAT gateway for external communications
This parameter is only available if you select Specific port for Port Type. Range: 1 to 65535
You can enter a specific port number or a port range, for example, 80 or 80-100.
Instance Type
The type of the instance that will be providing services accessible from the Internet. Possible values are:
- Server
- Virtual IP address
- Custom
NIC
The NIC of the server. This parameter is available if you set Instance Type to Server.
Private IP Address
- In a VPC scenario, this parameter can only be set to the private IP address of a server in the NAT gateway's VPC. The server will provide services accessible from the Internet through DNAT.
- In a Direct Connect/Cloud Connect scenario, set this parameter to IP address of the server in your on-premises data center or your private IP address. This IP address is used by on-premises servers that are connected to a VPC through Direct Connect or servers in another VPC to provide services accessible from the Internet through DNAT.
- Configure the port of Private IP Address if you select Specific port for Port Type.
Private Port
The port of the server over which the originating requests will be forwarded
Range: 1 to 65535
Provides supplementary information about the DNAT rule. Enter up to 255 characters. Angle brackets (<>) are not allowed.
- Click OK.
Once the rule is created, its status changes to Running.
After you add a DNAT rule, add rules to the security group associated with the servers to allow inbound or outbound traffic. Otherwise, the DNAT rule does not take effect.
