Help Center/ MapReduce Service/ User Guide/ MRS Cluster O&M/ MRS Cluster Patch Description/ MRS 3.0.5.1 Patch Description
Updated on 2025-08-09 GMT+08:00
Basic Information
| Patch Version | MRS 3.0.5.1 |
| Release Date | 2021-08-14 |
| Resolved Issues | List of resolved issues in MRS 3.0.5.1: MRS Manager
Big data components
| Compatibility with Other Patches | The MRS 3.0.5.1 patch can resolve all the issues detected in MRS 3.0.5. |
Impact of Patch Installation
- During the installation of MRS 3.0.5.1, the executor and controller processes are automatically restarted and cluster functions on the management plane, such as job submission and cluster scaling, will be affected. Therefore, install the patch at an appropriate time.
- After you install the patch, restart the Spark2x, Hive, Yarn, Impala, Kudu, and Hue components on FusionInsight Manager for the patch to take effect. During the restart, some services may be unavailable for a short period of time. To minimize the impact on service continuity, perform the restart at a proper time.
- To install the MRS 3.0.5.1 patch, you need to manually download the patch file and install it on any master node in the cluster. For details, see the README.md file in the patch package.
- This patch must be also installed for any new node subsequently added to the cluster. To install the patch for this new node, install the patch on the master node and restart the corresponding service.
Patch Download Addresses
- CN-Hong Kong: https://mrs-container1-patch-ap-southeast-1.obs.ap-southeast-1.myhuaweicloud.com/MRS_Common_Script/MRS_3.0.5.1_Patch_All_20210724.tar.gz
- AP-Singapore: https://mrs-container1-patch-ap-southeast-3.obs.ap-southeast-3.myhuaweicloud.com/MRS_Common_Script/MRS_3.0.5.1_Patch_All_20210724.tar.gz
- AP-Bangkok: https://mrs-container1-patch-ap-southeast-2.obs.ap-southeast-2.myhuaweicloud.com/MRS_Common_Script/MRS_3.0.5.1_Patch_All_20210724.tar.gz
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
