Updated on 2026-09-24 GMT+08:00
MRS 2.1.0.1 Patch Description
Basic Information
Table 1 Basic information
Patch Version
MRS 2.1.0.1
Release Date
2020-02-12
Resolved Issues
List of the resolved issues in MRS 2.1.0.1:
MRS Manager
The return results of Hive SQL statements submitted by V2 jobs have been optimized, and the issue that V2 jobs fail to be submitted using an agency token has been solved.
MRS big data components
HiveServer out of memory (OOM) has been solved for MRS Hive: HIVE-10970 and HIVE-22275.
Compatibility with Other Patches
None
Impact of Patch Installation
During the installation of MRS 2.1.0.1 patches, MRS Manager and Hive are restarted. During the restart, the services are temporarily unavailable.
After MRS 2.1.0.1 patches are installed, log in to the Master1 node of the MRS cluster and delete the job directory in HDFS.
  • For a cluster with Kerberos authentication disabled, run the following command to delete the job directory in HDFS:
    hdfs dfs -rm -r /mrs/mrsjob/hive
  • For a cluster with Kerberos authentication enabled, perform the following operations to delete the job directory in HDFS:
    1. Run the following command and enter the password to perform authentication.
      kinit hdfs
    2. Run the following command to delete the job directory in HDFS:
This step is not required for a new MRS cluster because the directory does not exist in HDFS.
