MRS 2.0.1.3 Patch Description
Basic Information
| Patch Version | MRS 2.0.1.3 |
| Release Date | 2019-12-25 |
| Resolved Issues | List of the resolved issues in MRS 2.0.1.3: MRS Manager The cluster scaling logic has been optimized and the TCP connection leak issues have been solved at the background of V1 job management APIs. MRS big data components The following issues have been solved for MRS Hive: HiveServer out of memory (OOM); slow MergeFile phase if a large number of small files exist; files not found in the load partition phase of insert overwrite, and file merging failure during HIVE-22373:Container reuse. |
| List of the resolved issues in MRS 2.0.1.2: MRS Manager The following issue has been solved: Scale-out fails occasionally due to timeout that occurs when ResourceManager executes refreshNodes. | |
| List of the resolved issues in MRS 2.0.1.1: MRS Manager The following issue has been solved: OOM occurs on the executor of MRS Master nodes due to repeated node scale-in or scale-out. MRS big data components The following new function has been added: MRS Presto supports OBSFileSystem. The following issues have been solved for MRS Presto: The jstack is frequently printed and log files are too large to scroll. | |
| Compatibility with Other Patches | The MRS 2.0.1.3 patch package contains all content of the MRS 2.0.1.2 and MRS 2.0.1.1 patch packages. |
Impact of Patch Installation
During the installation of MRS 2.0.1.3 patches, MRS Manager and Presto are restarted. During the restart, the services are temporarily unavailable.
