ECS Specifications Supported by MRS Clusters
MRS uses ECSs of the following types in different application scenarios.
- General computing-plus: C3, C3ne, C6, and C6s
- Memory-optimized: M3, and M6
- Ultra-high I/O: I3 and IR3
- Kunpeng general computing-plus: KC1
MRS uses the following BMS:
- Kunpeng V1 BMS
ECS Flavor Naming Rules
AB.C.D
Example: m2.8xlarge.8
In the preceding flavor:
- A specifies the ECS type. For example, s indicates a general-purpose ECS, c a computing ECS, and m a memory-optimized ECS.
- B specifies the type ID. For example, the 1 in s1 indicates a general-purpose first-generation ECS, and the 2 in s2 indicates a general-purpose second-generation ECS.
- C specifies a flavor size and can be any of the following options: medium, large, and xlarge.
- D specifies the ratio of memory to vCPUs expressed in a digit. For example, value 4 indicates that the ratio of memory to vCPUs is 4.
ECS Specifications
Type |
vCPU |
Memory (GB) |
Flavor |
Virtualization Type |
C3 |
32 |
64 |
c3.8xlarge.2 |
KVM |
C3 |
16 |
64 |
c3.4xlarge.4 |
KVM |
C3 |
32 |
128 |
c3.8xlarge.4 |
KVM |
C3 |
60 |
256 |
c3ne.15xlarge.4 |
KVM |
C3ne |
32 |
64 |
c3ne.8xlarge.2 |
KVM |
C3ne |
16 |
64 |
c3ne.4xlarge.4 |
KVM |
C3ne |
32 |
128 |
c3ne.8xlarge.4 |
KVM |
C3ne |
60 |
256 |
c3ne.15xlarge.4 |
KVM |
C6 |
32 |
64 |
c6.8xlarge.2 |
KVM |
C6 |
64 |
128 |
c6.16xlarge.2 |
KVM |
C6 |
16 |
64 |
c6.4xlarge.4 |
KVM |
C6 |
32 |
128 |
c6.8xlarge.4 |
KVM |
C6 |
64 |
256 |
c6.16xlarge.4 |
KVM |
C6s |
32 |
64 |
c6s.8xlarge.2 |
KVM |
C6s |
64 |
128 |
c6s.16xlarge.2 |
KVM |
Type |
vCPU |
Memory (GB) |
Flavor |
M3 |
8 |
64 |
m3.2xlarge.8 |
KVM |
M3 |
16 |
128 |
m3.4xlarge.8 |
KVM |
M3 |
32 |
256 |
m3.8xlarge.8 |
KVM |
M3 |
60 |
512 |
m3.15xlarge.8 |
KVM |
M6 |
8 |
64 |
m6.2xlarge.8 |
KVM |
M6 |
16 |
128 |
m6.4xlarge.8 |
KVM |
M6 |
32 |
256 |
m6.8xlarge.8 |
KVM |
M6 |
64 |
512 |
m6.16xlarge.8 |
KVM |
Type |
vCPU |
Memory (GB) |
Flavor |
I3 |
8 |
64 |
i3.2xlarge.8 |
KVM |
I3 |
16 |
128 |
i3.4xlarge.8 |
KVM |
I3 |
32 |
256 |
i3.8xlarge.8 |
KVM |
I3 |
64 |
512 |
i3.16xlarge.8 |
KVM |
IR3 |
16 |
64 |
ir3.4xlarge.4 |
KVM |
IR3 |
32 |
128 |
ir3.8xlarge.4 |
KVM |
BMS Specifications
Flavor/ID |
vCPU |
Memory (GB) |
Network |
physical.ks1ne.4xlarge |
128 |
512 |
Distributed |
physical.ks1ne.8xlarge |
128 |
1024 |
