Common Configuration Files and Log Directories of an MRS Cluster
This section applies only to MRS 3.x or later.
Cluster Installation Directory
After an MRS cluster is created, the default installation directory of components in the cluster is /opt/Bigdata. Table 1 describes the main directories in the installation directory.
Directory |
Description |
/opt/Bigdata/common |
MRS cluster public resource directory, including the JDK/JRE directory and key storage directory |
/opt/Bigdata/components |
Directory for storing preset component information |
/opt/Bigdata/FusionInsight_Component name_Version number |
Installation directory of the registered component in an MRS cluster, for example, /opt/Bigdata/FusionInsight_HD_8.1.2.2 |
/opt/Bigdata/FusionInsight_Module name_Version number/install/FusionInsight-Component name-XXX |
Running directory of the installed component in an MRS cluster, for example, /opt/Bigdata/FusionInsight_HD_8.1.2.2/install/FusionInsight-Hadoop-3.1.1 |
/opt/Bigdata/FusionInsight_Current |
Workspace guidance directory of the installed component in an MRS cluster |
/opt/Bigdata/om-agent_Version number |
Running directory of the OMA module of MRS Manager |
/opt/Bigdata/om-server_Version number |
Running directory of the OMS module of MRS Manager |
/opt/Bigdata/packaged-distributables |
Installation directory of the MRS cluster component installation package |
/opt/Bigdata/third_lib/Component name |
Directory for storing user-defined JAR packages of components |
Component Log Directory
MRS cluster logs are stored in /var/log/Bigdata. For the run log directories of each component, see Table 2.
For details about how to view and download MRS cluster logs, see Viewing Logs of an MRS Cluster.
File Directory |
Log Content |
/var/log/Bigdata/audit |
Component audit log. |
/var/log/Bigdata/controller |
Log collecting script log. Controller process log. Controller monitoring log. |
/var/log/Bigdata/dbservice |
DBService log. |
/var/log/Bigdata/flume |
Flume log. |
/var/log/Bigdata/hbase |
HBase log. |
/var/log/Bigdata/hdfs |
HDFS log. |
/var/log/Bigdata/hive |
Hive log. |
/var/log/Bigdata/hetuengine |
HetuEngine logs. |
/var/log/Bigdata/httpd |
HTTPD log. |
/var/log/Bigdata/hue |
Hue log. |
/var/log/Bigdata/kerberos |
Kerberos log. |
/var/log/Bigdata/ldapclient |
LDAP client log. |
/var/log/Bigdata/ldapserver |
LDAP server log. |
/var/log/Bigdata/loader |
Loader log. |
/var/log/Bigdata/logman |
logman script log management log. |
/var/log/Bigdata/mapreduce |
MapReduce log. |
/var/log/Bigdata/nodeagent |
NodeAgent log. |
/var/log/Bigdata/okerberos |
OMS Kerberos log. |
/var/log/Bigdata/oldapserver |
OMS LDAP log. |
/var/log/Bigdata/metric_agent |
MetricAgent run log. |
/var/log/Bigdata/omm |
oms: complex event processing log, alarm service log, HA log, authentication and authorization management log, and monitoring service run log of the omm server. oma: installation log and run log of the omm agent. core: dump log generated when the omm agent and the HA process are suspended. |
/var/log/Bigdata/spark2x |
Spark2x log. |
/var/log/Bigdata/sudo |
Log generated when the sudo command is executed by user omm. |
/var/log/Bigdata/timestamp |
Time synchronization management log. |
/var/log/Bigdata/tomcat |
Tomcat log. |
/var/log/Bigdata/watchdog |
Watchdog log. |
/var/log/Bigdata/yarn |
YARN log. |
/var/log/Bigdata/zookeeper |
ZooKeeper log. |
/var/log/Bigdata/oozie |
Oozie log. |
/var/log/Bigdata/kafka |
Kafka log. |
/var/log/Bigdata/storm |
Storm log. |
/var/log/Bigdata/iotdb |
IoTDB log. |
/var/log/Bigdata/cdl |
CDL log. |
/var/log/Bigdata/upgrade |
OMS upgrade log. |
/var/log/Bigdata/update-service |
Upgrade service log. |
/var/log/Bigdata/patch |
Patch log. |
Common Configuration Files of the Client
During upper-layer application development and external system interconnection, you need to obtain MRS cluster configuration files using the MRS cluster client. For details about the common client configuration files of each component, see Table 3.
Component |
File Path |
File description |
Flink |
Client installation directory/Flink/flink/conf/flink-conf.yaml |
Primary configuration file for Flink, defining global settings such as cluster resource allocation, high availability, state backends, and network parameters. These configurations directly impact the execution environment of all submitted Flink jobs. |
HBase |
Client installation directory/HBase/hbase/conf/hbase-site.xml |
Basic configuration file used to start and manage the HBase cluster. It includes settings such as the data storage path, ZooKeeper connection details, and RegionServer configurations. |
HDFS |
Client installation directory/HDFS/hadoop/etc/hadoop/hdfs-site.xml |
Configuration file for HDFS. It defines critical parameters including data storage settings, redundancy policies, and node behavior. |
Client installation directory/HDFS/hadoop/etc/hadoop/core-site.xml |
Central configuration file for Hadoop. It defines key parameters such as the cluster's communication protocol, default file system, and global security settings. This file is essential and shared across all Hadoop components. |
HetuEngine |
Client installation directory/HetuEngine/hetuserver/conf/hetuserver-client.properties |
Configuration file for HetuEngine client connection parameters. |
Hive |
Client installation directory/Hive/config/hive-site.xml |
Primary configuration file for Hive, defining essential settings for both the client and server. |
Kafka |
Client installation directory/Kafka/kafka/config/client.properties |
Fundamental configuration file for the Kafka client, specifying general connection parameters used to communicate with a Kafka cluster. |
Client installation directory/Kafka/kafka/config/consumer.properties |
Kafka consumer configuration file that governs message consumption behavior, including offset management and partition assignment strategies. |
Client installation directory/Kafka/kafka/config/producer.properties |
Kafka producer configuration file that governs message sending behavior, including settings for retry policies, serialization formats, and partitioning strategies. |
Client installation directory/Kafka/kafka/config/server.properties |
Kafka server configuration file that defines essential cluster settings such as operating mode, network communication, storage policies, and performance tuning parameters. |
MapReduce |
Client installation directory/Yarn/config/mapred-site.xml |
Configuration file for MapReduce that specifies how jobs are executed, how resources are allocated, and how MapReduce integrates with YARN. |
Spark |
Client installation directory/Spark2x/spark/conf/spark-defaults.conf |
Configuration file for setting default parameters in Spark applications. It defines key runtime settings, including integration with cluster managers (such as YARN), resource allocation policies, memory management, network configurations, and performance tuning options. |
Yarn |
Client installation directory/Yarn/config/yarn-site.xml |
Configuration file for YARN that defines key settings for cluster resource management and task scheduling. It includes runtime parameters for core components like ResourceManager, NodeManager, and ApplicationMaster, which influence resource allocation, container management, and application scheduling across the cluster. |
