Updated on 2026-10-09 GMT+08:00
Restarting an MRS Cluster Component
During MRS cluster running, restart the components in the cluster if you have modified component settings, encountered infrastructure resource faults, or detected service process errors.
Components within an MRS cluster support both the standard restart and rolling restart.
  • Standard restart: concurrently restarts all components or instances in the cluster, which may interrupt services.
  • Rolling restart: restarts required components or instances without interrupting services as much as possible. Compared with a standard restart, a rolling restart takes a longer time and may affect service throughput and performance. To minimize or eliminate the impact on services during a component restart, you can perform rolling restarts to restart components or instances in batches. For instances in active/standby mode, the standby instance is restarted first, followed by the active instance.
    Table 4 describes the impact on services when a rolling restart is performed on components.
Restarting a cluster will stop the cluster components from providing services, which adversely affects the running of upper-layer applications or jobs. You are advised to perform rolling restarts during off-peak hours.
For details about whether services and instances in the current MRS cluster support rolling restart and the rolling restart parameters, see Component Restart Reference Information.
Notes and Constraints
  • Perform a rolling restart during off-peak hours.
    • If the service throughput of the Kafka service is high (over 100 MB/s) during a rolling restart, the restart will fail.
    • To avoid RegionServer restart failures caused by heavy loads during an HBase rolling restart, increase the number of handles if the requests per second of each RegionServer on the native interface exceed 10,000.
  • Before restarting, check the current number of requests in HBase. If the number of requests on the native interface for each RegionServer is over 10,000, increase the number of handles to prevent overloading.
  • Preferentially perform a rolling instance or service restart and select Only restart instances whose configurations have expired.
Impact on the System
  • If the number of Core nodes in a cluster is less than six, services may be affected for a short period of time.
  • Table 4 describes the impact of a component rolling restart.
  • The IAM users have been synchronized in advance. You can do this by clicking Synchronize next to IAM User Sync on the Dashboard page of the cluster details.
  • You have logged in to MRS Manager. For how to log in, see Accessing MRS Manager.
  1. Access the MRS cluster component management page.
    • Using the management console: Log in to the MRS console, click the cluster name to access the cluster details page, and then click the Components tab.
    • Using MRS Manager (MRS 3.x or later): Log in to MRS Manager and choose Cluster > Services.
    • Using MRS Manager (MRS 2.x or earlier): Log in to MRS Manager and click Services.
  2. Click the name of the target component to go to the details page.
  3. On the service details page, expand the More drop-down list and select Restart Service or Service Rolling Restart.
  4. Enter the user password (required when you perform operations on Manager), confirm the operation impact, and click OK to restart the system.
    If you select rolling restart, set parameters listed in Table 1. (Required parameters may vary by version, set parameters based on the actual GUI.)
    Figure 1 Performing a rolling restart on Manager
    Table 1 Rolling restart configuration parameters
    Example Value
    Restart only instances with expired configurations
    Whether to restart only the modified instances in a cluster.
    The name of this parameter may be different in other versions.
    Enable rack strategy
    Whether to enable the concurrent rack rolling restart strategy. This parameter takes effect only for roles that meet the rack rolling restart strategy. (The roles support rack awareness, and instances of the roles belong to two or more racks.)
    This parameter can be set only when a rolling restart is performed on HDFS or YARN.
    Data Nodes to Be Batch Restarted
    Number of instances that are restarted in each batch when the batch rolling restart strategy is used. The default value is 1.
    • This parameter is valid only when the batch rolling restart strategy is used and the instance type is DataNode.
    • This parameter is invalid when the rack strategy is enabled. In this case, the cluster uses the maximum number of instances (20 by default) configured in the rack strategy as the maximum number of instances that are concurrently restarted in a rack.
    • This parameter can be set only when a rolling restart is performed on some components, such as HDFS, HBase, YARN, Kafka, and Flume. The actual value displayed on the GUI prevails.
    • The number of HBase RegionServer nodes that can be concurrently restarted during a rolling restart cannot be manually configured. It is automatically adjusted based on the total number of RegionServer nodes.
      The adjustment rules are as follows: If there are less than 30 nodes, one node is restarted at a time. If there are less than 300 nodes, two nodes are restarted at a time. If there are 300 or more nodes, 1% of the total node count is restarted at a time.
    Batch Interval
    10
    Interval (in seconds) between restarting two batches of instances during a rolling restart. The default value is 0.
    Setting the batch interval parameter can increase the stability of the big data component process during the rolling restart.
    You are advised to set this parameter to a non-default value, for example, 10.
    Decommissioning Timeout Interval
    1800
    How long (in seconds) a role instance waits to be terminated after being marked for decommissioning during a rolling restart. This parameter can be set only when a rolling restart is performed on Hive or Spark.
    Some roles (such as HiveServer and JDBCServer) stop providing services before the rolling restart. Stopped instances cannot be connected to new clients. Existing connections will be completed after a period of time. An appropriate timeout interval can ensure service continuity.
    Batch Fault Tolerance Threshold
    0
    Tolerance times when the rolling restart of instances fails to be batch executed. The default value is 0, which indicates that the rolling restart task ends after any batch of instances fails to restart.
  5. After the restart or rolling restart of a component is successful, Running Status of the component is Normal and Configure Status is Synchronized.
    Figure 2 MRS cluster components
Table 2 provides services and instances that support or do not support rolling restart in the MRS cluster.
Table 2 Services and instances that support or do not support rolling restart
Service
Instance
Rolling Restart
Alluxio
AlluxioJobMaster
Yes
AlluxioMaster
ClickHouse
ClickHouseServer
Yes
ClickHouseBalancer
CDL
CDLConnector
Yes
CDLService
Flink
FlinkResource
No
FlinkServer
Flume
Flume
Yes
MonitorServer
Guardian
TokenServer
Yes
HBase
HMaster
Yes
RegionServer
ThriftServer
RESTServer
HetuEngine
HSBroker
Yes
HSConsole
HSFabric
QAS
HDFS
NameNode
Yes
Zkfc
JournalNode
HttpFS
DataNode
Hive
MetaStore
Yes
WebHCat
HiveServer
Hue
Hue
No
Impala
Impalad
No
StateStore
Catalog
IoTDB
IoTDBServer
Yes
Kafka
Broker
Yes
KafkaUI
No
Kudu
KuduTserver
Yes
KuduMaster
Loader
Sqoop
No
MapReduce
JobHistoryServer
Yes
Oozie
Oozie
No
Presto
Coordinator
Yes
Worker
Ranger
RangerAdmin
Yes
UserSync
TagSync
Spark
JobHistory
Yes
JDBCServer
SparkResource
Storm
Nimbus
Yes
UI
Supervisor
Logviewer
Tez
TezUI
No
YARN
ResourceManager
Yes
NodeManager
ZooKeeper
Quorumpeer
Yes
Table 3 lists the instance startup duration.
Table 3 Restart duration for reference
Service
Restart Duration
Startup Duration
Remarks
IoTDB
3min
IoTDBServer: 3 min
CDL
2min
  • CDLConnector: 1 min
  • CDLService: 1 min
ClickHouse
4min
  • ClickHouseServer: 2 min
  • ClickHouseBalancer: 2 min
HDFS
10min+x
  • NameNode: 4 min + x
  • DataNode: 2 min
  • JournalNode: 2 min
  • Zkfc: 2 min
x indicates the NameNode metadata loading duration. It takes about 2 minutes to load 10,000,000 files. For example, x is 10 minutes for 50 million files.
The startup duration fluctuates with reporting of DataNode data blocks.
YARN
5min+x
  • ResourceManager: 3 min + x
  • NodeManager: 2 min
x indicates the time required for restoring ResourceManager reserved tasks. It takes about 1 minute to restore 10,000 reserved tasks.
MapReduce
2min+x
JobHistoryServer: 2 min + x
x indicates the scanning duration of historical tasks. It takes about 2.5 minutes to scan 100,000 tasks.
ZooKeeper
2min+x
quorumpeer: 2 min + x
x indicates the duration for loading znodes. It takes about 1 minute to load 1 million znodes.
Hive
3.5min
  • HiveServer: 3 min
  • MetaStore: 1 min 30s
  • WebHcat: 1 min
  • Hive service: 3 min
Spark2x
5min
  • JobHistory2x: 5 min
  • SparkResource2x: 5 min
  • JDBCServer2x: 5 min
Flink
4min
  • FlinkResource: 1 min
  • FlinkServer: 3 min
Kafka
2min+x
  • Broker: 1 min + x
  • Kafka UI: 5 min
x indicates the data restoration duration. It takes about 2 minutes to start 20,000 partitions for a single instance.
Storm
6min
  • Nimbus: 3 min
  • UI: 1 min
  • Supervisor: 1 min
  • Logviewer: 1 min
Flume
3min
  • Flume: 2 min
  • MonitorServer: 1 min
Doris
2 min
  • FE: 1 min
  • BE: 1 min
  • DBroker: 1 min
Table 4 describes the impact on the system during the rolling restart of components and instances.
Table 4 Impact on the system
Component
Service Interruption
Impact on System
ClickHouse
During the rolling restart, if the submitted workloads can be complete within the timeout period (30 minutes by default), there is no impact.
Nodes undergoing a rolling restart reject all new requests. This affects single-replica services, the ON CLUSTER operation, and workloads dependent on the instances being rolling-restarted. If a request that is being executed is not completed within the timeout period (30 minutes by default), the request fails.
DBService
All services are normal during the rolling restart.
During the rolling restart, alarms indicating a heartbeat interruption between the active and standby DBService nodes may be reported.
Doris
Doris services will not be interrupted during the rolling restart only when the following conditions are met:
  • ELB or DBalancer is used to connect to Doris for job submission.
  • Tables being read or written must have multiple replicas (three replicas are recommended).
  • If the submitted workloads are complete within the timeout period (30 minutes by default), the workloads are not affected. Otherwise, the workloads will fail.
During the rolling restart, the total resources decrease, affecting the maximum memory and CPU resources that can be used by jobs. In extreme cases, the jobs may fail due to insufficient resources. If a job times out (30 minutes by default), retry the job.
Flink
The FlinkServer UI cannot be accessed during the rolling restart.
Flume
To prevent service interruptions and data loss, the following conditions must be met:
  • Persistent cache, for example File Channel, is used.
  • Flume cascading is configured.
  • Flume client sink supports fault failover or load balancing.
  • Data loss may occur if channels do not have persistent cache.
  • The performance deteriorates for a short period of time during the fault failover.
Guardian
None
HBase
HBase read and write services are normal during the rolling restart.
  • Real-time read and write performance may deteriorate during RegionServer rolling restart.
  • During the HMaster rolling restart, services other than the real-time read and write services (excluding BulkLoad) are affected.
    Creating a table (create)
    Creating a namespace (create_namespace)
    Disabling a table (disable, disable_all)
    Re-creating a table (truncate and truncate_preserve)
    Moving a region (move)
    Taking a region offline (unassign)
    Merging regions (merge_region)
    Splitting a region (split)
    Enabling balance (balance_switch)
    DR operations (add_peer, remove_peer, enable_table_replication, disable_peer, show_peer_tableCFs, set_peer_tableCFs, enable_peer, disable_table_replication, set_clusterState_active, and set_clusterState_standby)
    Querying the cluster status (status)
HDFS
  • An active/standby switchover is triggered for NameNodes. During the switchover, there is temporarily no active NameNode. As a result, the HDFS unavailable alarm may be reported, and running read/write tasks may encounter errors. However, HDFS services are not interrupted.
  • If a rolling restart is being performed on DataNodes, errors may be reported for some data that is being read or written. Read/write speed is affected when the client retries.
  • During the rolling restart of ZKFC, an active/standby NameNode switchover occurs.
  • During the rolling restart of HDFS, enabling the rack policy may affect service read and write operations.
If a third-party client is used, the reliability of the third-party client during the rolling restart cannot be guaranteed.
HetuEngine
  • There are at least two HSFabric instances, and at least two HSFabric instances are used for interconnection. Cross-domain services are not interrupted during the rolling restart.
  • HetuEngine services are not interrupted during the rolling restart of HSBroker, HSConsole, and QAS.
  • The rolling restart of HetuEngine compute instances can be performed only when there are at least two Coordinator and Worker nodes, respectively. The rolling restart of compute instances does not interrupt services.
  • HSFabric nodes undergoing the rolling restart reject all new requests. SQL requests that are being executed will fail if they are not complete within the timeout period (30 minutes by default).
  • During the rolling restart, you cannot perform O&M operations on the HSConsole page.
  • During the rolling restart of HetuEngine compute instances, the performance decreases by approximately 20%. If the memory consumed by SQL execution exceeds 80% of query_max_total_memory, SQL tasks fail.
Hive
During the rolling restart, services with execution time longer than the decommissioning timeout period may fail.
  • If the execution time of an existing task exceeds the timeout interval of the rolling restart, the task may fail during the restart. You can retry the task if it fails.
  • Nodes undergoing a rolling restart do not receive new requests. The number of requests processed by other instance nodes increases, and these nodes occupy more resources.
Kafka
During the rolling restart, the read and write of Kafka topics with multiple replicas are normal, but operations on Kafka topics with only a single replica are interrupted.
  • Topics and partitions cannot be added, deleted, or modified.
  • When acks is set to 1 or 0 in Producer, the next Broker will be forcibly restarted if the replica data is not synchronized within 30 minutes during the rolling restart. For a dual-replica partition whose replicas are in two brokers, when unclean.leader.election.enable is set to true in the server configuration, data may be lost; when unclean.leader.election.enable is set to false, the partition may not have a leader for a period of time until the broker starts.
KrbServer
During the rolling restart, Kerberos authentication of a cluster may take a longer time.
LdapServer
MapReduce
None
  • You cannot view the task logs during the rolling restart.
  • In the scenario where only one JobHistoryServer instance is deployed, stopping JobHistoryServer will make all upper-layer components that depend on it become faulty.
Ranger
The RangerAdmin, RangerKMS, and PolicySync instances of Ranger are configured in active-active mode, and these instances can provide services in turn during the rolling restart. However, UserSync supports only a single instance, so users cannot be synchronized during a restart.
The user synchronization period is 5 minutes, and UserSync takes a short time to restart. Therefore, the UserSync restart has little impact on user synchronization.
Spark
Only the listed items are affected; other services are not.
  • When performing a rolling restart on HBase, you cannot create or delete Spark on HBase tables in Spark.
  • When you perform a rolling restart on HBase, an active/standby switchover is triggered for HMaster. During the switchover, the Spark on HBase function is unavailable.
  • If you have used the advanced Kafka APIs, interruptions and data loss may occur when Spark reads data from or writes data to Kafka during the rolling restart.
  • During the rolling restart of ZooKeeper, spark-beeline fails to start.
  • During the rolling restart of YARN, Spark jobs may trigger retries at the task, stage, and application levels.
  • During the rolling restart of JDBCServer of Spark, long-running tasks will be terminated.
YARN
  • An active/standby switchover is triggered for ResourceManager nodes during the rolling restart. Running tasks will encounter errors, but services are not interrupted.
  • During the rolling restart of NodeManager, containers submitted to the node may be retried on other nodes.
  • During the rolling restart of YARN, tasks running on YARN may experience exceptions due to excessive retries.
  • If a NodeManager rolling restart is triggered at the moment when the ApplicationMaster of a newly submitted job starts, the job may fail.
ZooKeeper
ZooKeeper read and write operations are normal during the rolling restart.
  • The rolling restart affects the ClickHouse service. During the instance restart, ClickHouse tables become read-only on each QuorumPeer instance for approximately 10 seconds.
  • The rolling restart causes ZooKeeper disconnection in Loader HA. Loader automatically retries for three times, each for 10 seconds. If ZooKeeper still cannot be connected, the active LoaderServer becomes the standby one and then a new active LoaderServer will be elected.
Helpful Links
