Performing a Health Check for an MRS Cluster
The cluster health check includes three key items: object health, related alarms, and custom metrics. The check result may not match the health status shown on the UI. A health check includes MRS Manager, service-level, and host-level health checks:
- MRS Manager health checks focus on whether the unified management platform can provide management functions properly.
- Service-level health checks focus on whether components can provide services properly.
- Host-level health checks focus on whether host indicators are normal.
To ensure that cluster parameters, configurations, and monitoring are correct and that the cluster can run stably for a long time, you can perform a health check during routine maintenance.
Video Tutorial
This video shows how to perform routine health checks on MRS clusters and nodes.
The UI may vary depending on the version. This tutorial is for reference only.
- The IAM users have been synchronized in advance. You can do this by clicking Synchronize next to IAM User Sync on the Dashboard page of the cluster details.
- You have logged in to MRS Manager. For how to log in, see Accessing MRS Manager.
Performing a Health Check on Manager
For MRS 3.x and later versions:
- Log in to FusionInsight Manager of the MRS cluster.
For details about how to log in to FusionInsight Manager, see Accessing MRS Manager.
- Choose O&M > Health Check.
By default, all saved health check reports are displayed in a list. For details, see Table 1.
- Start health checks.
For MRS 2.x or earlier:
- Start a health check.
Click Services and choose More > Start Service Health Check.
- Set periodic automatic health check.
- Click System, click Check Health Status under Maintenance, and click Configure Health Check.
- Set the Max. Number of Health Check Reports. The value must be an integer ranging from 1 to 100.
- Click Periodic Health Check to enable this function. Set the check period to Daily, Weekly, or Monthly based on O&M requirements, and click OK to save the configuration.
Health Check on the MRS Management Console
Only MRS 1.9.2 clusters support health check management on the MRS console.
- Log in to the MRS console.
- On the Active Clusters page, select a running cluster and click its name to switch to the cluster details page.
- Start the health check.
- Perform the health check for all services.
- Perform the health check for a service.
Click Components. In the service list, click the target service name and choose More > Start Service Health Check.
- Perform the health check for a host.
Click Nodes, expand the node group information, select the check box of the target hosts, and choose Node > Start Host Health Check.
