Help Center/ MapReduce Service/ User Guide/ Managing Clusters/ Managing an MRS Cluster/ Exporting MRS Cluster Configuration Parameters
Updated on 2025-08-09 GMT+08:00
Administrators can export key server configuration parameters of MRS cluster components for quick check or backup.
- The IAM users have been synchronized in advance. You can do this by clicking Synchronize next to IAM User Sync on the Dashboard page of the cluster details.
- You have logged in to MRS Manager. For how to log in, see Accessing MRS Manager.
Exporting Cluster Configurations on the Console
- Log in to the MRS console.
- On the Active Clusters page, select a running cluster and click its name to switch to the cluster details page.
- Choose Configuration > Export Cluster Configuration in the upper right corner of the page to export cluster configurations to the local PC.
This operation applies to MRS 2.x and earlier versions.
Figure 1 Exporting cluster configurations
Exporting Cluster Configurations Using Manager
- Log in to MRS Manager.
- Choose Cluster > Dashboard.
- Choose to export the configurations of all services in the cluster in batches.
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
