Help Center/ MapReduce Service/ User Guide/ Managing Clusters/ Managing the MRS Cluster Client/ Updating the MRS Cluster Client After the Server Configuration Expires
Updated on 2026-09-24 GMT+08:00
An MRS cluster provides a client for you to connect to a server, view task results, or manage data. If you modify service configuration parameters on Manager and restart the service, you need to download and install the client again or use the configuration file to update the client.
For clusters of MRS 2.x or earlier, the original client is stored in the /opt/client directory of all nodes in the cluster by default when you create a cluster. After the cluster is created, only the client of a Master node can be directly used. To use the client of a Core node, you need to update the client configuration file first.
Updating Client Configurations (Version 3.x or Later)
Method 1
  1. Log in to MRS Manager and choose Cluster > Dashboard > More > Download Client. For MRS 3.3.0 or later, click Download Client on the Homepage page.
    For details about how to log in to MRS Manager, see Accessing MRS Manager.
  2. Choose More > Download Client > Configuration Files Only.
    The generated compressed file contains the configuration files of all services.
    Figure 1 Downloading the client configuration file
  3. Set the parameters.
    For versions earlier than MRS 3.3.1:
    Determine whether to generate a configuration file on the cluster node.
    • If yes, select Save to Path, and click OK to generate the client file. By default, the client file is generated in /tmp/FusionInsight-Client on the active management node. You can also store the client file in other directories, and user omm has the read, write, and execute permissions on the directories. Then go to Step 4.
    • If no, click OK, specify a local save path, and download the complete client. Wait until the download is complete and go to Step 4.
    For MRS 3.3.1 and later versions:
    1. Set the Select Download Location parameter as needed.
      • Server: Download the file to the active OMS node of the cluster.
      • Browser: Download the file to the local computer.
      • Remote Node: Download the file to a node other than the active OMS node.
    2. Set Save to Path as prompted. If you select Browser as the download location, left this parameter blank.
    3. If you select Remote Node, configure the required parameters by referring to Table 1.
      Table 1 Parameters for downloading to a remote node
      Example Value
      Host IP Address
      IP address of the remote node.
      The platform type of the remote node must be the same as that of the downloaded client. Otherwise, the client may fail to be installed.
      x.x.x.x
      Host Port
      Host port of the remote node.
      22
      Username
      Username for logging in to the remote node.
      The user must have the write permission for the path.
      xxx
      Authentication Method
      You can choose one of the following methods:
      • Password: Use the password for login.
      • SSH private keys: Use SSH private keys for login.
      • None: To use this method, passwordless login needs to be enabled.
      Password
      Password
      Enter the password when Authentication Method is set to Password.
      Password for logging in to the remote node.
      xxx
      SSH private keys
      This parameter is mandatory when Authentication Method is set to SSH private keys.
      Click Add and select the SSH private key file to upload.
      Auto Deployment
      Whether to enable auto deployment. This parameter is mandatory when Select Client Type is set to Complete Client.
      • If you set this parameter to yes, the client is automatically installed and deployed on the current node.
      • If you set this parameter to no, the client will not be automatically installed and deployed. You need to manually install the client after it is downloaded.
      Yes
      Deployment Path
      This parameter is mandatory when Auto Deployment is set to Yes. If only the configuration file is downloaded, this parameter will not be displayed.
      The deployment path must be empty if it already exists on the remote node. Otherwise, it will be created automatically. The path also requires operate and write permissions.
      /opt/testclient
  4. Use WinSCP to save the compressed file to the client installation directory, for example, /opt/hadoopclient, as the client installation user.
  5. Decompress the software package.
    Run the following commands to go to the directory where the client is installed, and decompress the file to a local directory. For example, the downloaded client file is FusionInsight_Cluster_1_Services_Client.tar.
    cd /opt/hadoopclient
    tar -xvf FusionInsight_Cluster_1_Services_Client.tar
  6. Verify the software package.
    Run the following command to verify the decompressed file and check whether the command output is consistent with the information in the sha256 file.
    sha256sum -c FusionInsight_Cluster_1_Services_ClientConfig_ConfigFiles.tar.sha256
    The following information is displayed:
    FusionInsight_Cluster_1_Services_ClientConfig_ConfigFiles.tar: OK
  7. Decompress the package to obtain the configuration file.
    tar -xvf FusionInsight_Cluster_1_Services_ClientConfig_ConfigFiles.tar
  8. Run the following command in the client installation directory to update the client using the configuration file:
    sh refreshConfig.sh Client installation directory Directory where the configuration file is stored
    For example, run the following command:
    sh refreshConfig.sh /opt/hadoopclient /opt/hadoopclient/FusionInsight_Cluster_1_Services_ClientConfig_ConfigFiles
    If the following information is displayed, the configurations have been updated successfully.
    Succeed to refresh components client config.
Method 2:
  1. Log in to the client installation node as user root.
  2. Go to the client installation directory, for example, /opt/hadoopclient and run the following commands to update the configuration file:
    sh autoRefreshConfig.sh
  3. Enter the username and password of the FusionInsight Manager administrator and the floating IP address of OMS.
    To obtain the floating IP address of OMS, log in to the Master2 node remotely, and run the ifconfig command. In the command output, eth0:wsom indicates the floating IP address of OMS. Record the value of inet. If the floating IP address of OMS cannot be queried on the Master2 node, switch to the Master1 node to query and record the floating IP address. If there is only one Master node, query and record the IP address on the Master node.
  4. Enter the names of the components whose configuration needs to be updated. Use commas (,) to separate the component names. Press Enter to update the configurations of all components if necessary.
Method 3 (for MRS 3.3.1 and later):
  1. Log in to FusionInsight Manager of the MRS cluster.
    For details about how to log in to FusionInsight Manager, see Accessing MRS Manager.
  2. Choose Cluster > Client Management. On the displayed page, check whether there is the client you want to operate.
    • If yes, go to Step 3.
    • If no, click Add, configure information about the client, and click OK. Go to Step 3.
  3. Click Update in the Operation column of the client you want to update.
    If you need to update clients in batches, select the target clients (use the same installation user) and choose More > Batch Update.
  4. Select the checkbox for risk confirmation, configure the information in Table 2, and click OK.
    During a configuration update, clients may not function properly and client services may be interrupted.
    Table 2 Parameters for updating the client configuration
    Example Value
    Password
    Password/SSH Private Keys
    xxx
    • Enter the password if Authentication Method is set to Password.
    • Upload the private key file if Authentication Method is set to SSH private keys. Click Select File and select a local file to upload.
    Host Port
    22
    Host port of the node where the client is to be updated
    Installation Package Path
    /tmp/FusionInsight-Client/
    Path for storing the installation package of the updated client
    If there already is a client file in the path, it will be overwritten. For a remote node, write permission for the path is required.
Updating Client Configurations (Version 2.x or Earlier)
Method 1 (applicable to all versions)
  1. Log in to MRS Manager and choose Services.
  2. Click Download Client.
    Set Client Type to Only configuration files, Download To to Server, and click OK to generate the client configuration file. The generated file is saved in the /tmp/MRS-client directory on the active management node by default. You can customize the file path.
    Figure 2 Downloading the client configuration file
  3. Query and log in to the active Master node.
  4. If you use the client in the cluster, run the following command to switch to user omm. If you use the client outside the cluster, switch to user root.
    sudo su - omm
  5. Go to the client directory.
    cd Client installation directory
  6. Update client configurations.
    sh refreshConfig.sh Client installation directoryFull path of the client configuration file package
    Example:
    sh refreshConfig.sh /opt/Bigdata/client /tmp/MRS-client/MRS_Services_Client.tar
    ReFresh components client config is complete.
Method 2:
  1. After the cluster is installed, run the following command to switch to user omm. If you use the client outside the cluster, switch to user root.
    sudo su - omm
  2. Go to the client directory.
    cd {Client installation directory}
  3. Run the following command and enter the name of an MRS Manager user with the download permission and its password (for example, the username is admin and the password is the one set during cluster creation) as prompted to update client configurations.
  4. After the command is executed, the following information is displayed, where XXX indicates the name of the component installed in the cluster. To update client configurations of all components, press Enter. To update client configurations of some components, enter the component names and separate them with commas (,).
    Components "xxx" have been installed in the cluster. Please input the comma-separated names of the components for which you want to update client configurations. If you press Enter without inputting any component name, the client configurations of all components will be updated:
    If the following information is displayed, the configurations have been updated:
    If the following information is displayed, the username or password is incorrect.
    login manager failed,Incorrect username or password.
    • This script automatically connects to the cluster and invokes the refreshConfig.sh script to download and update the client configuration file.
    • By default, the client uses the floating IP address specified by wsom=xxx in the Version file located in the installation directory to update the client configurations. To update the configuration file of another cluster, change the value of wsom=xxx in the Version file to the floating IP address of the target cluster before performing this step.
