MRS Cluster Overview
MRS Console
After creating a cluster, you can use the MRS console or MRS Manager to manage and maintain it, as well as view basic information.
- The MRS console's cluster management page allows you to monitor and manage nodes, components, alarms, files, and jobs related to the cluster.
- MRS Manager is the O&M management system of MRS and provides unified cluster management capabilities for services deployed in clusters.
For further information on the capabilities of the MRS console and Manager, refer to Table 1.
Operation |
Console |
Manager |
Changing subnets, adding security group rules, controlling OBS permissions, managing agencies, and synchronizing IAM users |
Yes |
No |
Adding node groups, scaling out, scaling in, and upgrading specifications |
Yes |
No |
Isolating hosts, starting all roles, and stopping all roles |
Yes |
Yes |
Downloading the client, starting services, stopping services, and perform rolling restart of services |
Yes |
Yes |
Viewing the instance status of services, configuring parameters, and synchronizing configurations |
Yes |
Yes |
Viewing cleared alarms and events |
Yes |
Yes |
Viewing the alarm help |
Yes |
Yes |
Setting thresholds for threshold alarms |
No |
Yes |
Adding message subscription specifications |
Yes |
No |
Managing files |
Yes |
No |
Managing jobs |
Yes |
No |
Managing tenants |
Yes |
Yes |
Managing tags |
Yes |
No |
Setting permissions (adding and deleting users, user groups, and roles) |
No |
Yes |
Backing up component data and restoring data |
No |
Yes |
Logging metadata operation audit |
No |
Yes |
Monitoring resources |
Yes |
Yes |
MRS Cluster Management Objects
There are various fundamental objects in MRS, which are listed in Table 2.
Object |
Description |
Example |
Component |
Function set that can complete specific business. |
KrbServer and LdapServer |
Instance |
Specific instance of a component, which can also be referred to as a component. |
KrbServer |
Role |
Function entity that forms a complete component, usually called role. |
KrbServer is composed of the KerberosAdmin role and KerberosServer role. |
Role instance |
Specific instance of a service role running on a host. |
KerberosAdmin that is running on Host2 and KerberosServer that is running on Host3 |
Host |
An ECS running Linux OS. |
Host1 to Host5 |
Rack |
Physical entity that contains multiple hosts connecting to the same switch. Physical racks are invisible to ECSs in an MRS cluster. Rack names on MRS Manager represent logical racks. |
Rack1 contains Host1 to Host5. |
Cluster |
Logical entity that consists of multiple hosts and provides various services. |
Cluster names Cluster1 consists of five hosts (Host1 to Host5) and provides services such as KrbServer and LdapServer. |
