Updated on 2026-09-24 GMT+08:00
Backing Up Hive Service Data
To ensure Hive service data security routinely or before a major operation on Hive (such as upgrade or migration), you need to back up Hive service data. The backup data can be used to recover the system if an exception occurs or the operation has not achieved the expected result, minimizing the adverse impacts on services.
Hive service data backup tasks can be created on FusionInsight Manager. The system supports both automatic and manual backup modes.
  • Hive backup and restoration cannot identify the service and structure relationships of objects such as Hive tables, indexes, and views. When executing backup and restoration tasks, you need to manage unified restoration points based on service scenarios to ensure proper service running.
  • Hive backup and restoration do not support Hive on RDB data tables. You need to back up and restore original data tables in external databases independently.
  • If the backup data of the standby cluster is lost in an existing Hive backup task that contains Hive on HBase tables, the next incremental backup will fail, and you need to create a Hive backup task again. However, the next full backup task will be normal.
  • After the backup function of FusionInsight Manager is used to back up the HDFS directories at the Hive table level, the Hive tables cannot be deleted and recreated.
MRS clusters support multiple data path types for backing up Hive service data.
  • RemoteHDFS: indicates that backup files are stored in the HDFS directory of the standby cluster.
  • NFS: indicates that backup files are stored in NAS using the NFS protocol.
  • CIFS: indicates that backup files are stored in NAS using the CIFS protocol.
  • SFTP: indicates that backup files are stored in the server using the SFTP protocol.
  • OBS: indicates that backup files are stored in OBS.
Notes and Constraints
MRS 3.5.0 and later versions support the backup of Hive service data to OBS.
  • To back up data to a remote HDFS, the following conditions must be met:
    • A standby cluster for backing up data has been created. Its authentication mode must be the same as that of the active cluster.
    • If the active cluster is deployed in security mode and the active and standby clusters are not managed by the same FusionInsight Manager, mutual trust has been configured. For details, see Configuring Mutual Trust Between MRS Clusters. If the active cluster is deployed in normal mode, mutual trust is not required.
    • Cross-cluster replication has been configured for the active and standby clusters. For details, see Enabling MRS Inter-Cluster Replication.
    • Time is consistent between the active and standby clusters, with the NTP services on both clusters configured to use the same time source.
    • The HDFS in the standby cluster has sufficient space. You are advised to save backup files in a custom directory.
  • Backup policies, including the backup task type, period, backup object, backup directory, and Yarn queue required by the backup task are planned based on service requirements.
  • On the HDFS client, you have executed the hdfs lsSnapshottableDir command as user hdfs to check the list of directories for which HDFS snapshots have been created in the current cluster and ensured that the HDFS parent directory or subdirectory where data files to be backed up are stored does not have HDFS snapshots. Otherwise, the backup task cannot be created.
  • If you want to back up data to NAS, you have deployed the NAS server in advance.
  • If you want to back up data to OBS, you have connected the current cluster to OBS and have the permission to access OBS. Only MRS 3.5.0 or later supports data backup to OBS.
  1. Log in to MRS Manager.
    For details about how to log in to MRS Manager, see Accessing MRS Manager.
  2. Choose O&M > Backup and Restoration > Backup Management.
  3. Click Create.
  4. Set Name to the name of the backup task.
  5. Select the cluster to be operated from Backup Object.
  6. Set Mode to the type of the backup task.
    Periodic indicates that the backup task is executed by the system periodically. Manual indicates that the backup task is executed manually.
    Table 1 Periodic backup parameters
    Example Value
    Started
    2024/11/22 10:29:11
    Time when the task should start for the first time.
    Period
    1 day
    Task execution interval. Supported values are Hours and Days.
    Backup Policy
    Full backup at the first time and incremental backup subsequently
    • Full backup at the first time and incremental backup subsequently
    • Full backup every time
    • Full backup once every n times
    Incremental backup is not supported for Manager data and component metadata. Only Full backup every time is supported.
    If Path Type is set to NFS or CIFS, incremental backup cannot be used. When incremental backup is used for NFS or CIFS backup, the latest full backup data is updated each time the incremental backup is performed. Therefore, no new recovery point is generated.
  7. In Configuration, choose Hive > Hive.
  8. Select a backup directory type for Path Type of Hive.
    Table 2 Path of backup data
    Path Type
    RemoteHDFS
    Destination NameService Name
    Name of the NameService in the standby cluster.
    • You can set it to the NameService name (haclusterX, haclusterX1, haclusterX2, haclusterX3, or haclusterX4) of the built-in remote cluster.
    • You can also set it to the NameService name of a configured remote cluster.
    IP Mode
    IP version of the target IP address. The system automatically determines the IP version, such as IPv4 or IPv6, based on the cluster network type.
    Target NameNode IP Address
    Service plane IP address of the active or standby NameNode in the standby cluster.
    Target Path
    HDFS directory in the standby cluster for storing backup data.
    • The path cannot be configured as an HDFS hidden directory, such as a snapshot or recycle bin directory.
    • The path cannot be configured as a default system directory, such as /hbase or /user/hbase/backup.
    Maximum Number of Backup Copies
    Number of backup files that can be retained in the backup directory.
    Queue Name
    Name of the YARN queue used for backup task execution.
    The name must be identical to that of a queue currently running properly in the cluster.
    Maximum Number of Maps
    Maximum number of maps in a MapReduce task. The default value is 20.
    Maximum Map Bandwidth (MB/s)
    Maximum bandwidth of a map. The default value is 100.
    NameService Name
    NameService name of the backup directory. The default value is hacluster.
    NFS
    IP Mode
    Server IP Address
    IP address of the NAS server.
    Server Shared Path
    Shared directory configured on the NAS server by the user.
    The shared directory of the server cannot be set to the root directory. The user group and owner group of the shared directory must be configured as nobody:nobody.
    Queue Name
    NameService Name
    CIFS
    IP Mode
    Server IP Address
    Port
    Port number used by the CIFS protocol to connect to the NAS server.
    The default value is 445.
    Username
    Username configured during CIFS protocol setup.
    Password
    Password configured during CIFS protocol setup.
    Server Shared Path
    Queue Name
    NameService Name
    SFTP
    IP Mode
    Server IP Address
    IP address of the server where the backup data is stored.
    Port
    Port number used by the SFTP protocol to connect to the backup server.
    The default value is 22.
    Username
    Username used to connect to the server over SFTP.
    Password
    Password used to connect to the server over SFTP.
    Server Shared Path
    Backup path on the SFTP server.
    Queue Name
    NameService Name
    OBS
    Target Path
    OBS directory for storing backup data.
    Queue Name
  9. Set Maximum Number of Recovery Points to the number of snapshots that can be retained in the cluster.
  10. Set Backup Content to one or multiple Hive tables to be backed up.
    You can select backup data using either of the following methods:
    • Adding a backup data file
      Click the name of a database in the navigation pane to show all the tables in the database, and select specified tables.
      MRS 3.2.0 or later:
      1. Click Add.
      2. Select the table to be backed up under File Directory, and click Add to add the table to Backup Content.
      3. Click OK.
    • Selecting using regular expressions
      1. Click Query Regular Expression.
      2. In the first text box, enter the name of the database where the Hive tables reside. Ensure that the database is an existing database. For example, enter default.
      3. Enter a regular expression in the second text box. Standard regular expressions are supported. For example, to get all tables in the database, enter ([\s\S]*?). To get tables whose names consist of letters and digits, for example, tb1, enter tb\d*.
      4. Click Refresh to view the displayed tables in Directory Name.
      5. Click Synchronize to save the result.
      • When entering regular expressions, click or to add or delete an expression.
      • If the selected table or directory is incorrect, click Clear Selected Node to deselect it.
  11. Click Verify to check whether the backup task is configured correctly.
    The possible causes of the verification failure are as follows:
    • The target NameNode IP address is incorrect.
    • The queue name is incorrect.
    • The parent directory or subdirectory of the HDFS directory where data files to be backed up are stored has HDFS snapshots.
    • The directory or table to be backed up does not exist.
    • The name of the NameService is incorrect.
  12. Click OK.
  13. In the Operation column of the created task in the backup task list, click More and select Back Up Now to execute the backup task.
    After the backup task is executed, the system automatically creates a subdirectory for each backup task in the backup directory. The format of the subdirectory name is Backup task name_Data source_Task creation time, and the subdirectory is used to save latest data source backup files. All the backup file sets are stored in the related snapshot directories.
Helpful Links
Backup Hive service data may be restored if data is accidentally modified, deleted, or requires retrieval; if major Hive operations (such as upgrades or significant data adjustments) cause exceptions in system data or fail to achieve the expected result; if all modules fail and become unavailable; or if data needs to be migrated to a new cluster. For detailed operations, refer to Restoring Hive Service Data.
