Help Center/ MapReduce Service/ User Guide/ Managing Clusters/ Managing MRS Cluster Components/ Checking the Running Status of an MRS Cluster Component
Updated on 2026-10-09 GMT+08:00
After creating an MRS cluster, you can check the status of each service component and its role instance on the console or Manager. This will assist you in detecting any performance issues with the component.
  • The IAM users have been synchronized in advance. You can do this by clicking Synchronize next to IAM User Sync on the Dashboard page of the cluster details.
  • You have logged in to MRS Manager. For how to log in, see Accessing MRS Manager.
Checking Component Status
You can check the component status using either the management console or the MRS Manager.
  1. Log in to the MRS console.
  2. On the Active Clusters page, select a running target cluster and click its name to go to the cluster details page.
  3. On the MRS cluster details page, click Components to view the service status, health status, and configuration status.
    Figure 1 Checking component status
    Table 1 Component status description
    Status Type
    Status
    Operating Status
    Started
    The service is started.
    Stopped
    The service is stopped.
    Failed to start
    Failed to start the role instance.
    Failed to stop
    Failed to stop the role instance.
    Unknown
    Initial service status after the background system restarts.
    Health Status
    Good
    Indicates that all role instances in the service are running properly.
    Faulty
    The running status of at least one role instance is Faulty or the status of the service on which the current service depends is abnormal.
    If the running status of a service is Faulty, an alarm is generated. Rectify the fault based on the alarm information.
    Unknown
    All role instances in the service are in the Unknown state.
    Restoring
    The background system is restarting the service.
    Partially Healthy
    When a dependent service fails, external systems cannot access its related APIs. This affects upper-layer businesses that rely on the service.
    HBase, Hive, Spark, and Loader may be in the Partially Healthy state.
    • If YARN is installed but is abnormal, HBase is in the Partially Healthy state.
    • If HBase is installed but is abnormal, Hive, Spark, and Loader are in the Partially Healthy state.
    Configuration Status
    Synchronized
    Indicates that the latest configuration takes effect.
    Configuration expired
    The latest configuration does not take effect after the parameter modification. You need to restart related services.
    Configuration failed
    If a communication or read/write exception occurs during parameter configuration, you can use the synchronization configuration function to rectify the fault.
    Configuring
    Parameters are being configured.
    Unknown
    Current configuration status cannot be obtained.
  4. Click a component name to go to the component details page and view the detailed running information about the component.
    Figure 2 Viewing cluster component details
  5. Click Instances to view the detailed running information about each role instance in the service.
    • The list of role instances shows all the instances for each role in the cluster, including their running and configuration status, hosts, and IP addresses.
    • You can click an instance name to go to the instance details page and view the basic information, configuration file, instance logs, and monitoring metric graphs of the instance.
    Figure 3 Checking the status of cluster component instances
    Table 2 Instance status
    Status Type
    Status
    Running Status
    Good
    The instance is running properly.
    Bad
    The instance cannot run properly.
    Decommissioned
    The instance is out of service.
    Not started
    The instance is stopped.
    Unknown
    The initial status of the instance cannot be detected.
    Starting
    The instance is being started.
    Stopping
    The instance is being stopped.
    Restoring
    An exception may occur in the instance and the instance is being automatically rectified.
    Decommissioning
    The instance is being decommissioned.
    Recommissioning
    The instance is being recommissioned.
    Failed to start
    The instance fails to be started.
    Failed to stop
    The instance fails to be stopped.
    Synchronized
    The latest configuration takes effect.
    Configuring
    Unknown
  1. Log in to FusionInsight Manager of the MRS cluster.
    For details about how to log in to FusionInsight Manager, see Accessing MRS Manager.
  2. Choose Cluster > Services. The component management page is displayed.
    The service list displays the running status, configuration status, role type, and number of instances of each component.
    On MRS Manager of MRS 2.x or earlier, click Services to open the component management page.
    Figure 4 Checking the status of cluster components
    Table 3 Manager component status description
    Status Type
    Status
    Running Status
    Normal
    The component is running properly.
    Faulty
    The component cannot work properly.
    Partially Healthy
    Some enhanced functions of the component cannot work properly.
    Not started
    The component is stopped.
    Unknown
    The initial status of the component cannot be detected.
    Starting
    The component is being started.
    Stopping
    The component is being stopped.
    Failed to start
    The component fails to be started.
    Failed to stop
    The component fails to be stopped.
    Synchronized
    • Expired (Manager 2.x or earlier)
    • Expired (Manager 3.x and later)
    Failed
    • Configuring (Manager 2.x or earlier)
    • Synchronizing (Manager 3.x and later)
    Unknown
  3. Click a component name to view its details.
  4. Click Instances to view the detailed running information about each role instance in the service.
    Figure 5 Checking the status of cluster component instances
    Table 4 Manager instance status description (3.x and later versions)
    Status Type
    Status
    Running Status
    Normal
    Faulty
    Decommissioned
    Not started
    Unknown
    Starting
    Stopping
    Restoring
    Decommissioning
    Recommissioning
    Failed to start
    Failed to stop
    Synchronized
    Expired
    Failed
    Synchronizing
    Unknown
    Table 5 Manager instance status description (2.x and earlier versions)
    Status Type
    Status
    Operating Status
    Started
    The role instance has been started.
    Stopped
    The role instance has been stopped.
    Failed to start
    Failed to stop
    Decommissioning
    The role instance is being decommissioned.
    Decommissioned
    The role instance has been decommissioned.
    Recommissioning
    The role instance is being recommissioned.
    Unknown
    Initial role instance status after the background system restarts.
    Health Status
    Good
    The role instance is running properly.
    Restoring
    The background system is restarting a role instance.
    Bad
    The instance role is experiencing an abnormality, such as the inability to access a port due to a non-existent PID.
    Unknown
    The host where a role instance resides does not connect to the background system.
    Partially Healthy
    The role instance is partially running properly.
    Synchronized
    Expired
    The latest configuration does not take effect after the parameter modification. Related services need to be restarted.
    Failed
    The communication is incorrect or data cannot be read or written during the parameter configuration. Click Synchronize Configuration to rectify the fault.
    Configuring
    Unknown
