Creating an Alarm Rule
You can create an alarm rule to customize monitored objects and notification policies, so that you can be well-informed of the statuses of transcoding tasks in a timely manner.
- Log in to Huawei Cloud console. Choose .
- Click
in the upper left corner of the console and select AP-Singapore or CN North-Beijing4. - In the navigation pane, choose Alarm Management > Rule Settings.
In some regions, the path is Alarm Management > Alarm Rules.
- In the upper right corner of the page, click Create Alarm Rule.
- Set parameters as prompted.
For more information, see Creating an Alarm Rule. The key parameters are as follows:
- Name: The system generates a random name, and you can change it if needed.
- Alarm Type: Select Metric.
- Cloud Product: MPC - Transcoding tasks
- Resource Level: Select Specific dimension.
- Monitoring Scope: Select All resources, Resource groups, or Specific resources.
- Click Create.
After the alarm rule is created, the system automatically notifies you when an alarm is triggered.
