JSON Message Body
Table 1 describes the fields in a JSON message.
Parameter |
Type |
Description |
event_type |
String |
Event type.
Possible values include:
transcode_info |
Transcoding information. This parameter is used only when event_type is TranscodeComplete or TranscodeStart. |
thumbnail_info |
Snapshot information. This parameter is used only when event_type is ThumbnailComplete. |
animated_graphics_info |
GIF image information. This parameter is used only when event_type is AnimatedGraphicsComplete. |
remux_info |
Packaging information. This parameter is used only when event_type is RemuxComplete. |
Parameter |
Type |
Description |
task_id |
string |
Task ID |
status |
tring |
Event status.
create_time |
string |
Time when a task is created |
start_time |
string |
Time when a task starts |
end_time |
string |
Time when a task ends |
intput |
Storage location of an input file |
output |
Storage location of an output file |
description |
string |
Task description |
media_detail |
Transcoding details. This field is unavailable if transcoding fails. |
Parameter |
Type |
Description |
features |
String[] |
Task name |
origin_para |
Input file information |
output_video_paras |
Information about multiple output media files |
output_watermark_para |
Watermark information |
Parameter |
Type |
Description |
duration |
Integer |
Duration of an input file |
file_format |
String |
Input file format |
video |
Input video file information |
audio |
Input audio file information |
Parameter |
Type |
Description |
width |
Integer |
Video width |
height |
Integer |
Video height |
bitrate |
Integer |
Video bitrate |
frame_rate |
Integer |
Video frame rate |
codec |
string |
Video codec |
Parameter |
Type |
Description |
codec |
string |
Audio codec |
sample |
Integer |
Audio sampling rate |
channels |
Integer |
Audio channel |
bitrate |
Integer |
Audio bitrate |
Parameter |
Type |
Description |
template_id |
Integer |
ID of the template used by the output video |
size |
Integer |
Video size |
pack |
string |
Video packaging format |
video |
Video |
Output file (video) information |
audio |
Audio |
Output file (audio) information |
file_name |
string |
Output file name |
conver_duration |
double |
Converted duration |
error |
Error |
Error information |
Parameter |
Type |
Description |
time_duration |
Int32 |
Watermark duration |
Parameter |
Type |
Description |
task_id |
String |
Task ID |
status |
String |
Event status.
create_time |
String |
start_time |
String |
end_time |
String |
description |
String |
Task description. If a task is abnormal, this field indicates error details. |
input |
output |
Output file information |
output_param |
Animated GIF parameters |
Parameter |
Type |
Description |
location |
String |
Region where the OBS bucket is. |
bucket |
String |
OBS bucket name. |
object |
String |
File path.
file_name |
String |
Name of an output file.
Parameter |
Type |
Description |
format |
String |
Output file format. Currently, only GIF format is supported. |
width |
Integer |
Width of an output file |
height |
Integer |
Height of an output file |
start |
Integer |
Start time Unit: millisecond |
end |
Integer |
End time |
frame_rate |
Integer |
Frame rate of the output file |
Parameter |
Type |
Description |
task_id |
string |
Task ID |
status |
tring |
Event status.
create_time |
string |
start_time |
String |
end_time |
string |
intput |
output |
description |
string |
Task description |
output_file_name |
String |
Output file name |
thumbnail_info |
PicInfo[] |
Snapshot details. This field is unavailable if capturing snapshots fails. |
Parameter |
Type |
Description |
pic_name |
String |
Snapshot file name |
Parameter |
Type |
Description |
task_id |
String |
Task ID |
status |
String |
Event status.
create_time |
String |
start_time |
String |
end_time |
String |
description |
String |
input |
output |
output_param |
Packaging parameters |
