Updated on 2026-02-25 GMT+08:00
Before using MPC, you need to perform the operations in this section.
- Real-name authentication is required for both individual and enterprise users. For details, see real-name authentication.
If you are a Huawei Cloud (International) user, you need to complete real-name authentication when you:
- Purchase and use cloud services on Huawei Cloud nodes in the Chinese mainland. In this case, real-name authentication is required by the laws and regulations of the Chinese mainland.
- Select the Chinese mainland region for MPC.
- MPC can be used only after being enabled. Figure 1 shows the overview page before MPC is enabled. Click Enable Now. On the page shown in Figure 2, view the billing details of each billing item and read the Huawei Cloud MPC Service Agreement carefully before enabling MPC.
- By default, MPC adopts pay-per-use billing. The generated service fees will be directly deducted from your account balance. Ensure that your account is available and has sufficient balance.
