Adding a Stage or Step
You can customize a migration workflow to fit your requirements better by adding stages or steps to the workflow.
- You can add a stage or step before or after an existing stage or step only when the existing stage or step is in the Waiting or Paused status. If the existing stage or step is in the Running or Complete status, you cannot add a new one before or after it.
- If the previous stage is in Running, Paused, or Complete state, you can only add a stage after the existing stage. This is also true for step additions.
- You cannot add steps after repeatable steps.
Adding a Stage
- On the migration workflow details page, move the cursor to the migration stage before or after which you want to add a stage. In the displayed window, choose Add Stage Before or Add Stage After.
- Enter a stage name and description, click Add Step, select a step type, enter a step name and description, and click Confirm. Multiple steps can be added.
- Click Confirm.
Manually added stages can be modified or deleted, but pre-defined stages cannot.
Adding a Step
- On the migration workflow details page, move the cursor to the step before or after which you want to add a step. In the displayed window, choose Add Step Before or Add Step After.
- Select a step type based on Table 1, enter a step name and description, and click Confirm.
- Go back to the migration stage and view the added step.
Manually added steps can be modified or deleted, but pre-defined steps cannot.
